Results 1 to 7 of 7
Thread: jolting when excellerating
    VY SV8 HBD---mmmm LS1
    Simon Champion! On The Volley Champion! Shootin Hoops Champion! Batting Champ Champion!
    Dec 2005
    Western Suburbs
    Default jolting when excellerating
    im having a lil trouble with my vr calais when i try 2 take off 2 fast the car tends 2 give a lil jolt then takes off even does this when the car is warm but somtimes the jolts harder and somtimes it bearly does it could this just b the computer or engines not warm enough i dont no help needed
    VY S2 Berlina
    Jul 2005
    Wide Bay, Queensland
    Quote Originally Posted by Joey_18
    im having a lil trouble with my vr calais when i try 2 take off 2 fast the car tends 2 give a lil jolt then takes off even does this when the car is warm but somtimes the jolts harder and somtimes it bearly does it could this just b the computer or engines not warm enough i dont help needed
    lol re type that last sentence (Quote: i dont help needed) yea ive got the same sorta problem and i only got a vr exec, id like to know the answer to this too
    Current: My Ride
    VY Series 2 Berlina, Leather
    Previous: Ride 2
    VR Executive, 5 Speed Manual, Ecotec 3.8
    Dec 2005
    Western Suburbs
    TheForgotten's Avatar
    TheForgotten is offline only human......
    VR EXEC
    Dec 2005
    quarantine
    VY S2 Berlina
    Jul 2005
    sorry joey_18 for hijacking lol, but my spark and fuel are fine, the fuel pressure is fine and the coils are the right resistance and ive repalced leads and plugs just incase, i went out and bought a compression tester and they are all around 1000 - 1100kpa,
    ive also replaced my TPS and IACv also got CAI and k&n hi flow filter installed
    not 100% sure my injectors are fine though, so i mite repalce them if no one else can suggest any thing,
    Current: My Ride
    Previous: Ride 2
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Is the transmission oil nice and bright red and doesn't smell burnt? If it needs changing it could be that the solenoids which make the cluches grab are a bit sticky or the trans filter may be partially blocked. You can do it your self for $30 gasket and filter and $25 for oil.
    VS Acclaim
    Apr 2004
    Default Filter?
    I had the same problem with my VS Acclaim, it was shuddering under load and it turned out to be a bodgy fuel filter. For a cheap guess I'd say change your fuel filter before having a more expensive look at things.
  1. Jolting at 80 -100kms
    By Scott98 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-11-2007, 01:51 PM
  2. Transmission jolting
    By Patrio7 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-01-2007, 08:46 AM
