+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 25 of 46
Thread: Ecu's
    vsII manual Guest
    Default Ecu's
    Can you use a auto ECU and put in a Manual chip? Will it function properly?
    VY S2 Berlina
    Jul 2005
    Wide Bay, Queensland
    ive heard that u can put an auto staright into a manual no worrys im not 100% sure tho
    Current: My Ride
    VY Series 2 Berlina, Leather
    Previous: Ride 2
    VR Executive, 5 Speed Manual, Ecotec 3.8
    VY S2 Berlina
    Jul 2005
    you dont really wont to buy a new one, they cost heaps i nearly had a heart attack when holden told me the price
    Current: My Ride
    Previous: Ride 2
    vsII manual Guest
    Quote Originally Posted by fitzy2005
    Thats why i want to know.
    My ecu is stuffed, had an accident with a water bottle.
    I have another manual chip and a spare auto ECU, thats why i need to know if it will work
    Doctor Bob's Avatar
    Doctor Bob is offline Grandpa Doctor Bob GTO Doctor Bob GTO
    VT V6 Exec & VN V6 Exec
    May 2004
    Mornington Peninsula
    Some VS PCM's dont have all the circuitry to read the manual speed sensor, you have to try it, if you get code 24 setting you have sruck out & will need to find either a manual one or an auto one with all the bits in it.
    Rob
    vsbt1
    Jul 2009
    Unhappy ecu or fuel emissions?
    hey guys got at a vs series 2 v6bt1 and i have changed the injectors and new gaskets and leads ,plugs ,oils,radiator, and everything new and im getting only 350 to a tank out of 65 litres thats wrong i have taken out the ecu and the memcal also and let it sit for 2 hours and then reinstalled it im still getting that same so is my ecu or pcm stuffed or needs remapping as i havent done that yet?got a 2.5 redback setup on and the cat converter gutted also,did the oxygen sensors both other day they good but what can i do ?to get 600klm to the tank?advise me on what to do and whom can do the remapping in frankston area cheers or near by what causes the car to run fast and fuel going fast ?done throttle body and bored that out and manifold also need help asap or can i swap me memcal over and try that?
    Nanos's Avatar
    Nanos is offline Not a Mod Nanos Berlina
    VXII LS1 Berlina Wagon
    Aug 2007
    Frankston
    ok so let get this right.
    you have put larger injectors in, thorttle body is bored out, you have full sprts system and want the car to go better but yet want to have fuel economy.
    firstly i would say put the standard injectors back in as they will work just fine on a stock motor. they would not be doing anything but waste petrol.
    Put standard throttle body back on also, without a retune the throttle body will be doing wierd things to the tune.
    if you want some more power get some mace high lift rockers then talk to dr bob for a mail order tune. dont expect much as it is a v6 at the end of the day. after you do tune and rockers i would say you will get around about 130rwkw's.
    Cobez's Avatar
    Cobez is offline LS-EXUAL Cobez has disabled reputation
    2004 S2 VY SS Ute
    Feb 2007
    Bigger injectors will do **** all for your almost stocko V6 dude. You would need a bigger fuel pump, even if you got that, pouring more fuel into your engine isn't going to help with power, it will just waste fuel. Bigger TB will do **** all as with the mods you have, you can put a bigger TB on, but your engine won't suck more air in because of it (unless of course you had it tuned).
    Try a set of good extractors for your exhaust, a flash tune from either Greenfoam, Doctor Bob or Delcowizzard (all forum members), a stage 2 shift kit and a good CAI.
    Gutting your cat is a dumb idea too, if a cop notices that (which a trained one could due to the awful noise it emits), so go to the wreckers and buy a stock cat and put that in. It does sweet F/A for power and even if it did, it's not worth the fine you would get for having a gutted cat.
    Quote Originally Posted by wikky
    As already stated, mate you're an absolute gherkin strummer.
    vsbt1
    Jul 2009
    ok then i will post me car here asap and i have got heaps of pics i need to know what happened to the manifold chambers any ideas and why and how this hap????then i rebuild the bloody thing and now still not good?anyway let me know all here ok guys and your advise and what u all think of me vsbt1 beast cheers and what else i can do to the car and will be for sale soon i have got 4 vr vs v6 bt1 clusters for sale also !and i have re done the klms on me car since i have done a engine rebuild!!!!!
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
    If you are gonna post up a thread on your car, do it in the "my ride" section not in here
    What happened to your "manifold chambers"???
    vsbt1
    Jul 2009
    hi i need help asap on what casued me engine to do this see the other pics of me car and the cop nasty!see me pics and let me know thanks and i need to find out wtf hap to me engine and caused this and how happened asap cheers any1 like me bt1 ?cheers!!!!!!!!!!!!!!!!!!!!
    vsbt1
    Jul 2009
    i dont know tell me what the @#$% happened i dont know until i took the manifold off what casued this and how cheers see me car pics and the cop pic to nasty!!!!!!!!!!!!!!!
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
    Ummm, well people could help if you told us where the pics are dude............
    savage1987's Avatar
    savage1987 is offline fail champion savage1987 GTS savage1987 GTS
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Quote Originally Posted by madvsbt1
    how about you actually keep these urgent requests in a SINGLE THREAD. Start a thread on it, don't just copy-paste and whore it all over the forum. I just had a look quickly and can't find any pics that you are talking about. Nobody pays attention to posts that don't make sense - like yours.
    If you start a thread on it, or provide a link to it if there already is one, and use proper English, I'm sure people will be happy to help as best they can
    Sam
    WTB: mulberry VN interior parts
    Quote Originally Posted by levymetal
    hahaha
    you taste weird man
    WAIT
    WHAT THE SHIT
    your taste in music is weird****
    Quote Originally Posted by kikki
    she was imagining you naked
    chicks all do that
  15. #15
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
    Yeah i must say i struggled to understand both those posts clearly.
  16. #16
    vsbt1
    Jul 2009
    try and see me profile and click on me car pics if not then tell me how to so it by adding them to me here ok cheers
  17. #17
    VS Berlina 3.8
    Dec 2008
    Quote Originally Posted by madvsbt1 View Post
    You also need to tell us what is actually wrong with the car. We can't identify problems by simply looking at a few photo's (unless it's a picture of your car on fire).
    So, start from the beginning, what is actually wrong with your car?
    You can start out by using this guide - Checking error codes VR/VS (Revised)
  18. #18
    vsbt1
    Jul 2009
    ok rjk heres whats the issue...
    bought a vsv6bt1 and then i had to get new replacement injectors then new spark plug leads and then fuel filter and oils and fluids and exhaust redback fitted by myself and then filled the tank up to the rim and only get between 350 400 klm only on cruise i had to do the manifold intake gaskets due to issues as in me profile pics and did both oxys on car and now i cant get the full fuel ecconomy as i should i have fitted all factory items back to the car throttle body,maf , and using cold air induction current now i have removed me ecu from the car and memcal and let them be for few hours and the exhaust is to loud now and baffles and the cat sounds tinny been gutted any ideas what i can do do fix the car up and get best klms on the road cheers.................should i try replace the ecu and the memcal or just the chip?
  19. #19
    vsbt1
    Jul 2009
    oh p.s. i had the car on a scannertool thing and all came back ok they told me to do the ecu and memcal and see if any changes if not then i will do replacement and theres no codes at all!!
  20. #20
    VS Acclaim V6
    Jul 2006
    dude, all your posts are scattered. Its givin me a headache trying to cyper them. Next time you post, use punctuation and paragraphs.
    i would say you have no codes logged coz your 'removed the ecu and chip'.
    Did you try and remove the MAF also?
  21. #21
    VX SS M6
    Jun 2005
  22. #22
    E46 M3
    Jun 2009
  23. #23
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
    Are you sure you aren't just heavy footed? I hear being heavy footed can contribute to bad fuel economy
  24. #24
    VS Berlina 3.8
    Dec 2008
    Quote Originally Posted by Cobez View Post
    Yes, I've heard running from the "nasty" "bloody pig cops" at 230Km/h can do that.
  25. #25
    vsbt1
    Jul 2009
    lol u should have seen there faces when they did end up getting me on the highway friggen funny !cant beleive the bike cop had to get a highway patrol to get me and keep up with me bike couldnt get me then the patrol car was driving to me same road but heading to me face on driving wrong way scary!then they had a cry at me and then they let me go weird thought i was gone for good and fined and car impounded at frankston but nothing came of it no ticket nothing weird!no yellow sticker nothing!!u work it out!!!!!!!!!!!!!!!!!!!! try again this time 250klm plus then on eastlink!see if the etag picks up and beeps!!
+ Reply to Thread
  1. Computers/ECU's
    By HÝPÕ-5L in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-05-2009, 02:57 AM
  2. Where to buy High Performance VK ECU's...?
    By vasrox in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 02-01-2007, 02:10 PM
  3. Performance enhaqnced ? Wolf3D ECU's
    By MrFeelgood in forum General
    Last Post: 22-04-2006, 08:53 AM
  4. PWR ECU's
    By Stretchomatic in forum LSx Development and Modification
    Last Post: 19-01-2006, 06:56 PM
