Harvs82
- Dec 29, 2005
- 1,134
- 24
- 38
- Age
- 41
- Location
- Glen Waverley VIC
- MY08 Subaru Liberty GT-B & MY16 VF II SS Redline
Hi All,
I'm having some issues with starting my car of late. Quite often when the engine has been running for a while, then shut down, then restarted a few mins later (like when getting fuel), the starter turns over the motor very slowly, and sometimes it seems to be not turning it over at all, and then just freewheeling. Normally if I try starting it again, it turns over ok.
This morning I filled up with fuel, and went to start it, and the starter could barely crank over the engine, I tried again, and then again, still no good. Waited a few mins, and had another go, still turned over slowly, but the engine did start, coughed and spluttered, and then stalled... this happened twice more, and then it did start up and run.
After work this arvo, same deal, very very slow cranking, and then running and then stalling. 3rd time starting it was ok. The battery is fine as far as I know, and the alternator also is ok, as its charging at just over 14 volts... So can anyone shed any light on what the problem could be?
