Results 1 to 7 of 7
Thread: cracked oil sump
    vs commodore ss
    Nov 2005
    Default cracked oil sump
    gday all
    tragedy struck today when i took a corner too fast and cracked my oil sump and i watched my oil spilll all over the road. does anyone know how much it should cost to replace the oil sump
    cheers all-
    VSAccCom Guest
    vs commodore ss
    Nov 2005
    VR Statesman
    Jan 2004
    Wyee
    If you cracked your sump the odds are you did some other damage as the sump is surrounded by many things.
    Perhaps its better you leave it off the road if you have the urge to drive so bloody stupid that you mount the footpath.
    Consider that anyone could have been ther and you could have killed them.
    I hope it costs you heaps and the mechanic rips you off good and thorough.
    LH Torana with Ecotec V6
    May 2004
    Tenambit, NSW.
    wow, im sure you have never put a foot wrong in your driving history too ...
    anyways to help the guy out, if its the actual sump that cracked i guess you have two options ...
    1. weld the crack up and re-install the sump.
    2. get one from the wreckers and replace it ....
    either way im not sure your going to be able to do it in the car, you might have to atleast get the front of the motor up high enough to get at the bolts etc ....
    if you can weld it in the car that might be the easiest option.
    HDT_aero is offline resident bush mechanic
    manual VN aero
    May 2005
    SA
    you will need a hoist to lift the engine right up untill its touching the trans tunnel (you need to undo the engine mounts to do this)
    then you needs get all the bolts of with a spanner (they are in prick spots so it takes a while but is doable) you will also need the exhaust manifolds undone off the heads to get enough clearance hight
    then you need to use an allen key to remove the sump pickup tube (as the sump catches on it and you have little clearance) so that you can remove the sump itself
    then reverse everything to get the new one in...
    use new gasket and gasket goo to avoid future hassles
    will take a good 3/4 of a day to get it all done
    im not admiring your car im looking in disgust
    Struma is offline Urge Surfer
    VS S2 Executive Ute
    Jan 2006
    Default Fixing Sump
    My VS is booked in for some work next week - including replacing the leaking sump gasket.
    This component of the job has been quoted to me at $580 (I am having a few other things done while we are there) - If I understand it correctly they will be removing the crossmember to drop the sump pan, but whichever way they do it, given the nature of the job I don't think it's too unreasonable. The car has got to be on the hoist and there seems to be a lot of crap to undo as well as supporting the motor while the 'member is out.
    Cheers,
  1. VR A/C Condenser Nut Cracked
    By Bilbs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-03-2008, 12:56 AM
  2. cracked plugs
    By 93 White Shark in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-03-2006, 10:03 PM
  3. cracked block
    By sulley in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 05-12-2005, 08:02 PM
  4. cracked sump
    By cizocizo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-08-2005, 12:26 AM
  5. Cracked Head?
    By Joshy in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 30-04-2004, 04:11 PM
