Anyone got any tips to remove the accelerator pedal on the VS? The pin holding it in seems as if it has been glued tight, and i've tried compressing with pliers and it just doesn't seem to budge.
Any help appreciated, cheers
yep, use a little screw driver (smaller than the dia of the dowel pin) that holds it on and push the pin through. All that holds it in place is the interference fit between the molded holes in the pedal and the dia of the pin![]()
PS: Note how the spring goes in tho,.... the pedal is worth $3 genuine from Holden
has anyone fitted the monaro pedals off ebay?
haha maybe we should swap pedals, mine doesnt wanna stay on, so ive been driving around for months with no pedal
