Results 1 to 4 of 4
Thread: horny
    statement's Avatar
    statement is offline reaching new limits
    VY/VZ Calais/Tonner
    Jun 2004
    north but not to north
    Unhappy horny
    hi guys , just wondering if anyone knows where on a statesman u can test to see if the horn working? cause the other day when i went to press it nothing happens but when the car alarm goes off it works, so is there a way to test the button on the wheel or a wire i could check?????
    in life some people need a little guidance, others just need a good kick
    VROCIOUS's Avatar
    VROCIOUS is offline Searching for more HP
    VR SS
    Sep 2005
    Perth, Western Australia
    i'd say then that the connection on the wheel button is not working. Pull the cover off the wheel and simply check the wires behind to make sure they are plugged in and even spray a contact cleaner such as crc or wd-40 to make sure all connections are good. also check to make sure no connections are severed down the steering column. however if you have an airbag this may be a problem...not too sure how to remove it without setting it off.
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    There different horns.
    On my VP, theres one near the passenger side strut tower, which is for the alarm, and dual horns behind the front bar under the drivers side headlight. I'd assume a statesman being a luxuary car would have a similar setup, so check the horns first before having to go rip off an airbag steering wheel.
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    statement's Avatar
    VY/VZ Calais/Tonner
    Jun 2004
    cool thanks guys, i'll testing b later today cheers
  1. HORNY - Silver Turbo Gemini
    By deathsminion in forum The Pub
    Last Post: 13-11-2004, 08:19 AM
  2. Horny
    By midnight.outlaw in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-01-2004, 09:09 PM
