Results 1 to 8 of 8
Thread: Steering column groaning noise
    ozzie_online88's Avatar
    ozzie_online88 is offline I'm No Superman...
    2003 VY S1 Exec
    Sep 2005
    Adelaide, South Australia
    Default Steering column groaning noise
    Hey guys..I have this groaning noise coming from my steering column, it only happens when ever the wheel is turned left(perfect when turning it the other way) and it doesent seem to get better/worse over time.
    I have read through a bunch of threds about this but im not sure if my problem is the same because it only happens when turning one way.
    Neways if someone could shed some light on my problem that would be great.
    Regards..Rhys Chappel
    Commodore 94 VR II Exec
    wizza Guest
    lol i had the same problem! now its gone away hahah dunno what it was try moving your column around. theres a lever to the bottom left of the wheel.
    2003 VY S1 Exec
    Sep 2005
    Hope it is that simple..I'll give it a go today and let you know how it works out
    Thanks
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Follow the path the steering column takes thru the firewall - where it passes thru the firewall there is a plastic "grommet" which acts as a bearing for the steering column - it groans when its dry - lubricate from below with a spray or grease on end of stick or whatever. Its not terminal so no panic.
    2003 VY S1 Exec
    Sep 2005
    hey hako, you wouldnt be able to give me more detailed instructions would ya? It's just, pretty much the only thing I know about cars is how to put a stereo in
    VS Berlina S2
    Sep 2004
    yeah hako is right, iv ehad the same prob with my VS.
    I thought it was my pwrsteer pump making the noise until i investigated more.
    All you need to do is take off the plastic cover under the dash and you will see where the steering column goes through the firewall, and you'll see the plastic grommett with the steering linkage goes through, spray with WD40 or whatever and the noise will go away.
    VLishes's Avatar
    VLishes is offline BaZMeG
    VS Calais SII
    Jul 2004
    Mine only does that when I first start the car, eventually goes away after 5 mins or so.
    VL Berlina
    Oct 2005
    ermm... check the fluids
  1. vr steering column
    By 5Lvrss in forum VL Holden Commodore (1986 - 1988)
    Last Post: 29-03-2006, 05:47 PM
  2. Steering column adjuster
    By Roh in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-02-2006, 01:34 PM
  3. Variatronic steering groaning noise
    By vsuterus in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-02-2006, 07:40 AM
  4. Groaning noise in VT 5spd
    By vtss5spd in forum V8 Development and Modification
    Last Post: 09-01-2006, 12:03 PM
  5. groaning noise from left hand side
    By hdt238 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-06-2005, 10:55 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
