More info on the cars needed.. auto/manual..previous issues..
But at a rough guess, it could be the injectors. If it was a faulty sensor (like oil) then a fault code would/should come up where as something to do with the injectors won't bring up an error. How many k's has the cars got? Being a Vs/VR then its more then likely over 100 k's so head down to your local supercheap or whatever and buy some injector cleaner and fill the car up on premium. If you've had your injectors cleaned or new ones installed within the last 20 thou then its another problem altogether...
LinkBack URL
About LinkBacks
