D
DaddyCool
Guest
I would like to know what could cause the engine in my VR to start running rough? Sometimes when i start the engine it runs like its only on 5 cyls. When i turn off for a few minutes and start again it would be OK... not this time. I have changed plugs & leads not long ago and swapped leads to try & find the stuffed one but still no change. Car runs on LPG and theres water coming out from the exhaust and a rich fuel smell.... have also removed the engine fuse and replaced with no improvements..Computer fault codes r ok with code 12. Help pls...:b:
