digisol
- Oct 6, 2005
- 537
- 5
- 0
- Location
- Central QLD
- Toyota Landcruiser
Having just put a LSD and housing from a VN into my VS all is not the same as one may think, so don't damage the brake lines off your VS diff as you will need them, the VN has different size threads on "all" brake line connections from the caliper to the body.
Add to that the LSD centre housing has no drain hole, the rear plate has to be removed just to change the oil so buy a new gasket before going home, bugger.
Of course that will apply with brake lines the same when putting VS rear ends into a VN.
Interesting.
Interesting.
