Results 1 to 17 of 17
Thread: Starting Issue
    Glover0 Guest
    Default Starting Issue
    Sometimes when i turn the key it just makes a click noise and nothing happens.
    Other times it cranks over fine but then revs really high for like 3-4 sec then drops down and idles at around 700.
    Any suggestions please
    VRII Acclaim
    Jul 2005
    Need more information. What makes a click noise?? Have you checked for error codes?
    VY S2 Berlina
    Jul 2005
    Wide Bay, Queensland
    sounds like key isnt making contact, or battery mite be flat, the reason it revs really high the drops back is the IAC valve is doing its job
    Current: My Ride
    VY Series 2 Berlina, Leather
    Previous: Ride 2
    VR Executive, 5 Speed Manual, Ecotec 3.8
    VRII Acclaim
    Jul 2005
    Yea if the click is coming from the engine I would be suspecting the battery. The instrument lights should go out when you turn the key and it makes its click. Check the battery voltage - check the terminals. Start the car and check the battery voltage. Either battery would be on its way out or the terminals arent making a good contact.
    Glover0 Guest
    When it clicks the radio turns off while holding the key turned.
    But all other instruments stay on.
    The click does sound like that the battery is flat but i can just return the key again and it will start perfect.
    Read other threads some people were saying fuel related?
    Fuel pump or regulator.
    VY S2 Berlina
    Jul 2005
    no not if it switched your stereo off.. check your terminals are clean and secure
    Current: My Ride
    Previous: Ride 2
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I think the radio, aircon/heater, warning lights and all other ignition switched things will turn off when the ignition key is turned to "start". This is designed to give the battery full voltage. When you release the key they all come back on again. The click sound could be coming from the "start relay" located under the bonnet near the battery - to test just swap with the hi-beam or ignition relay - if this isn't making contact the starter motor will not engage. If this makes no difference then it could be the starter solenoid contacts burnt which isn't all that common and in this case the solenoid would be trying to close the contacts to allow full battery power to the starter. This click would be louder than a relay click. Good Luck.
    VRII Acclaim
    Jul 2005
    Doubt very much its fuel pump. If you know what to listen for you can hear the fuel priming when you turn the ignition to on (without actually starting it). If you take the fuel pump relay out you will notice an absence of the sound. You need to listen very closely to hear it and if there is a bit of noise around you can miss it. That will tell you if everything is working nicely on the fuel side of things. Have you checked your battery yet?
    flc Guest
    I had a similar problem with my first car (subaru). Ended up being the starter motor. I used to have to give it a whack or two and then it would kick over and no problem. I remember it needed the brushes or something similar cleaned.
    VS2 Berlina
    Oct 2005
    Pakenham, Vic
    yeh sounds like starter problems
    had the same kinda sound wif old vk
    'I always thought xbox was a straight edge kid called bo.' :my:
    VS Series II Exec
    Nov 2004
    Guaranteed starter motor. I had this problem no more than 3 weeks back! AT first, you would click it once, nothing would happen, then it'd start the second time. But the day i got it fixed...took 4 or 5 goes before it actually started. $200 fix. A little expensive but hey, you need it to start the damn car! Take it to an auto elecs, get them to check it out, because it could also just be a faulty earthing wire, but more than likely it's the starter motor.
    Good luck,
    Boojakz.
    Pete284 is offline Banned
    Aug 2005
    VY S2 Berlina
    Jul 2005
    Quote Originally Posted by Pete284
    how many k's has the car done? what's it's badge (ie executive, etc.)?
    what does the badge have to do with anything??
    Current: My Ride
    Previous: Ride 2
    Glover0 Guest
    OK thanx guys
    yes starter motor new one installed is $200 wreckers 60 bucks.
    Instalation Hard?
  15. #15
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    you are sure it is the starter motor??? your initial problem had a high idle problem as well as no crank.
  16. #16
    Glover0 Guest
    High idle problem was iac Got new one and cleaned throttle body.
    I have to turn the key about 20 times now to get it to crank over.
  17. #17
    Milquetoast is offline I'm gettin' it...
    VR Executive
    Aug 2005
    Just moved to Melbourne.
    Contact in my opinion. The click is probably the fuel pump.
    Sucks. I got the same problem, but I am going to put the $85 into getting a new key before I blow $200 on a starter motor.
    I always thought a starter motor would give that metalic grind sound as opposed to nothing.
    The high rev is a good thing! I take great solace every time my car does it, 'coz it means my amp hasn't recked my alternator yet! Be happy with the high rev... you want the high rev.
    Alight!
    Who siphoned the blood out of my cat?!?!
  1. Starting Issue
    By ecotec in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-09-2010, 03:52 PM
  2. Odd starting issue
    By SSbeast in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-11-2007, 02:21 PM
  3. Not Starting/Stalling Issue
    By Emackulation in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-11-2007, 03:29 PM
  4. VS and VT ecotec Starting issue
    By yyg998vsute in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-12-2006, 11:38 PM
  5. weird starting issue
    By bradyboi in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-12-2006, 08:29 PM
