Results 1 to 4 of 4
Thread: cracked plugs
    93 White Shark Guest
    Default cracked plugs
    my plugs in the vr keep cracking.
    What the hell is going on??
    DeiCide's Avatar
    DeiCide is offline DeiCide
    VT
    Jan 2006
    r u doing them up to tight?
    1 quarter turn after hand tight.
    Check if their the right spec.
    VRII Acclaim
    Jul 2005
    What DeiCide said. Cant think of any other reason. Its not voltage or heat it would have to be mechanical stress.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    It is generally caused by not keeping the sparkplug socket (or tube spanner) straight on the plug when in stalling or removing - if the angle is not correct the walls of the socket press against the porcelain insulator and crack - doesn't take much to break them. The plug socket must be in a straight line with the plug. The porcelain is about as fragile as your grandmothers china.
  1. Replies: 25
    Last Post: 05-02-2011, 07:52 PM
  2. VR A/C Condenser Nut Cracked
    By Bilbs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-03-2008, 12:56 AM
  3. Boot Liner Plugs / Interior Plugs
    By xtr3 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-11-2007, 02:04 PM
  4. cracked oil sump
    By commo69 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-02-2006, 10:48 AM
  5. radiator cracked
    By S.T.S in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-11-2005, 05:13 PM
