nomad
- Dec 7, 2005
- 83
- 3
- 8
- Age
- 67
- Location
- North West Victoria
- VR Berlina wagon.
Did a search & found half the answer to my problem. Need to find the other half.
Problem came to light just after work, when the front drivers window started coming up at a 45 degree angle, back corner first. Took the door trim off after getting home to find 2 of the rivets holding the window regulator to the door broken. Found a solution how to fix by searching.
Trouble is, this is only half the problem. What has also happened is the plastic block on the front regulator arm has come out of the corresponding lift channel. It also looks like the leading edge of the window has come out of the run channel. I've once fixed this before about 30 years ago with a manual operated window, but not sure doing it with a power window.
Ideas or preferably a fix much appreciated.
