6h84eva
Certifiably Holden Mad
- Sep 3, 2004
- 38
- 0
- 0
- Age
- 54
- Location
- Conifer Grove, Auckland, NZ
- Website
- www.ithome.net.nz
- 2004 VZ SV6
Hi people
My VS Berlina is having an issue with the backlighting on the LCD display (the bit that shows the trip computer detail and the milage at the base of the instrument cluster).
About 6 months ago I lost one light and now a second has gone. I'm not concerned about a possible over-voltage - the car has done a few k's and I guess everything has an expiry date - but I cannot read the middle window any more at night and I like to use the setting that shows your current fuel consumption (like an old vacuum gauge used to) in this slot.
I pulled the cluster out to squiz at the thing when the first bulb went - as the local Holden dealer reckoned replacing the bulbs was easy - and the only bulbs accessible without pulling the PCB off the back were the backlights for the speedo / tach etc. Being a bit concerned for the well-being of the unit (as I had no manual at the time) I put it back without further investigation.
The manual I now have is no help. Has anyone ever replaced the bulbs that light up the LCD displays? If so, how is it done?
