Hi guys,
Just wondering if anyone knows if the rev limiter can be changed on a VS V6 Auto Eco Commodore. i.e. can the chip be reprogrammed to not rev out as much.
I want to change it from reving out a 5500RPM to 5000. Can it be done, and is it expensive etc.
Thankx guys.
oztech007
Book it into holden, i think the boys just edit memcal through tech2.
Not sure of the price though.
Nah cant be edited using Tech2. Already Called Holden. Said it cant be done. Anyone got any ideas.
Its stored in the eprom. A simple change to the data can fix it... if you know someone that can do it, or even better if you can do it yourself![]()
Talk to Dr Bob![]()
Driving a CURSED WH V6.
is there much more power to be gained by letting it rev out to 5,500rpm? (as opposed to 5,000rpm?)
Something I've Been Getting Into Lately....
Get Paid To Surf The Internet!
Program About To Be Released So I Jumped Aboard...
http://www.agloco.com/r/BBDB3431
i'll answer my own question!!! just pulled out my dyno sheet.
power peaks at 4,800rpm.
torque peaks at 3,600rpm.
so no extra power gain from letting her rev over 4,800rpm ????
oh wat 5500rpm, in my car VS v6 if u boot it from start it changes gears 5,900 with eco and power it dont change so i guess thats not normal?
thge only thing your going to gain out of holding your car till rev limiter is more revs in the next gear to utilise the power
stocky.. that's just cos you aren't giving it a chance to shift, the power drops back somewhat when you hit the limiter, hence the car has a chance to shift.
