Results 1 to 10 of 10
Thread: coolent needs flushing
    shanhsv's Avatar
    shanhsv is offline Luvo
    VS Berlina V8 5speed
    May 2005
    Muswellbrook,NSW
    Default coolent needs flushing
    Just wondering how much coolent a VS holds coz its a bad colour so im gonna flush it out and put new stuff in
    VR 5.0L BT1
    Jul 2005
    Pretty sure it's 12 Litres.
    Just get a bottle of concentrate, and mix it with distilled or demineralised water.
    shanhsv's Avatar
    May 2005
    Muswellbrook,NSW
    Well bugger me,thats alot.Any idea on wat i can use to make sure the insides are clean,im abit un-easy about just using a hose to run water through it.I need sumthin to clean the reserver bottle too
    DeiCide's Avatar
    DeiCide is offline DeiCide
    VT
    Jan 2006
    just take the reserver bottle off and clean it out with whatever eg. Orange power, or metho.
    You can buy some radiator flush treatments to thourghly clean insides.
    Might want to check your hoses too. (if original hoses will have heaps of sh!t in them)
    MY08 Subaru Liberty GT-B & VS Exec
    Dec 2005
    Glen Waverley VIC
    I've NEVER been able to get 12 litres into the VS cooling system. Easiest way to flush all the old crap out is to remove the bottom radiator hose, and then remove the thermostat and housing, and just continuously flush water through it until its clean, then fill up with straight water, assemble, go for a drive and then do it all again.
    I'd recommend using the Genuine Holden 50% concentrate coolant mix, I normally pour 6 litres of that in, and then just top the rest up with water, making up 12 litres in total.
    There are some other threads on here that may be of help to you, do a search and you'll find what you need.
    VRAddiction's Avatar
    VRAddiction is offline its never fast enough
    Vy SS Manual Ute
    Feb 2006
    [QUOTE=Harvs82]I've NEVER been able to get 12 litres into the VS cooling system. Easiest way to flush all the old crap out is to remove the bottom radiator hose, and then remove the thermostat and housing, and just continuously flush water through it until its clean, then fill up with straight water, assemble, go for a drive and then do it all again.
    QUOTE]
    ditto to that!!........and sticking a hose down it will be just fine....i do it everyday
    2004 VY2 SV8 A4
    Jun 2005
    Victoria Point, Brisbane
    Flushing with a hose is fine, but you must use at least 50% glycol in the entire system if you want the radiator to last as long as possible.
    Also the entire system holds 12 litres, but unless u remove the knock sensors and drain the block, you will only get about 9 into it. The block holds about 3 litres of water I think... even when u have drained the system.
    * Phreddy's Blaupunkt Aux input and line out mod
    * 18x8 inch Equus Kalibur Wheels with Maxxis MAV-1 235/40R18
    * Sureflo 3.5 inch medium-loud cat back exhaust
    Dec 2005
    Glen Waverley VIC
    Quote Originally Posted by shaggerz
    Yep thats right, thats why I dump the water after flushing it, connected everything back up, put all 6 litres of straight coolant into the radiator, and half fill the reservoir, and then just fill the rest up with water, that way you have your 50/50 mix.
    cunners3's Avatar
    cunners3 is offline ..............
    1997 VSII Wagon
    Aug 2005
    VIC
    Make sure you bleed it!!
    I pity those poor suckers on the freeway. Gas, brake, honk. Gas, brake, honk. Honk, honk, punch. Gas, gas gas!
    shanhsv's Avatar
    May 2005
    Muswellbrook,NSW
    thanx guys,once my boss gives me more work so i can replace the drive plate i'll get stuck into it
  1. oil mixed with coolent?
    By th1rt3en in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-09-2007, 07:44 AM
  2. Went to get Coolent temp sensor !!!!
    By chopsy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-06-2006, 09:02 PM
  3. Coolent Temp sensor
    By Warooda in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-04-2006, 01:16 AM
  4. Coolent leaking from the rear end
    By VNPOWER in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-07-2005, 12:23 AM
  5. Vk Calais Saying Low Coolent
    By vinh1981 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 15-06-2005, 11:01 PM
