+ Reply to Thread
Results 1 to 15 of 15
Thread: Centre Bearing Bracket Query & Tailshaft Ends Query
    Sojourner353 Guest
    Thumbs down Centre Bearing Bracket Query & Tailshaft Ends Query
    Hi all,
    Can anyone tell me which way the Centre Bearing Bracket goes on the VR?
    I was under my car today while it was on a hoist at Midas as I have been experiencing bad vibration and thought I may have had a bad Cat, they called me under to have a look and they said my Tailshaft was changing direction at the Centre Bearing, I notice the bracket that holds the Bearing to the car can offset the Bearing if put on wrong as the holes that hold the Bearing to the Bracket are off centre, there is a arrow on the underside of the bracket and at the moment that arrow is pointing to the back of the car, I feel it is in the wrong way as the Tailshaft is not sitting in the middle of the well with the bracket like this.
    So if anyone knows if this sounds wrong could you please help?
    Also if anyone knows the position of the X's on each end of the shaft where the uni's this would also be a big help are they meant to match at both ends (mirror image of each other)? The reason I ask this also is because mine don’t match and if they are meant to I suspect the CV Joint has not been put together correct when I had the Centre Bearing fixed.
    Thanks again for all the help,
    Regards,
    Kevin
    Boonz's Avatar
    Boonz is offline the holden mechanic Boonz Maloo Boonz Maloo
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    hey... the tailshaft shuld always go on the same way it came off because the cv's wear in a certain way and if changed then you get that shuddering feeling
    hako is offline Donating Member hako Senator hako Senator hako Senator
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Grerorys says to clearly mark all components to ensure they go back the same way. It also says "If the propellor shaft is separated, it is important to mark the relationship of the front and rear shafts to ensure correct universal joint phasing on assembly". The book says nothing of "X's" so maybe they were put there by a previous mechanic. Common practice is to centre punch one or more marks on each component before disassembly.
    Sojourner353 Guest
    Hi, I am aware of that, and that is why I am asking, I have a funny feeling the mechanic that done the Centre Bearing hasn’t put the CV Joint back together properly (right way), he recently told me I needed a new engine because I had a bad rattle in it (sounded like marbles rattling inside the engine) then told me $3000 reco fitted funny thing was the noise went away when he took the Drive Belt off and when I said where’s the noise he said I still needed a new engine, I ended up finding the Harmonic Balancer was stuffed and once replaced the noise was gone, can you see why I am concerned with his repair?
    Sojourner353 Guest
    Hi hako,
    The Gregorys Manual is very vague in relation to the Tailshaft, the X's I am talking about are where the uni's sit in each end (sorry mechanic term used there) its not punch marks, imagine the tailshaft is sitting on a bench and one end is Verticle, on mine the other end is out its not a mirror image of the other end, hence why I think my CV has been put together wrong.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I think I know what you mean - like at one end of the shaft the uni 'cross' is not the mirror image of the other end. The only thing I can suggest is that you talk to the people at Midas and ask when are they having another VR on the hoist - they are pretty common so I'd figure for sure that tomorrow morning they will have at least one on the hoist. Then eyeball just where the centre bearing sits and turn the prop shaft etc to try and ascertain whether your is the same. Take your digital camera and get some shots just to make sure. I've never touched my VS driveshaft but have had problems with a Jag XJ6 that I owned which had a 2 piece prop shaft identical to the Commodore except that the centre bearing was a ball bearing with uni's either side....the centreing of this bearing was very critical. Another way to get a look is to ask someone who you know who has a VR - just jack it up safely and put a mirror underneath or crawl under if you have stands for safety. Gregories mentions "phasing" which is unclear but seems to mean something about the angles which the unis pass thru when the shaft is rotating. ( the shaft rotational speed actually varies 4 times for every turn as the crosses in the uni changes angle - that is why constant velocity joints are called 'constant velocity' and are preferred when large directional changes are required like in front wheel drive) Your assumption re the CV joint may well be correct. Good Luck.
    VP Exec
    Jun 2005
    The uni. crosses aren't designed to line up in a Commodore. There should be about 15-20 degree difference when looked at along the direction of the shaft. Arrow to back of car is correct.
    Sojourner353 Guest
    Umm no the arrow is meant to point forward on my car, solid rear end it points back and 5 point rear end it points forward, I changed mine to point forward now 70% of the vibration has gone, also just replaced the rear mount under the gearbox and that has improved it even more, very happy now, thank for the help.
    VR Manual Sedan
    Sep 2009
    Default Tailshaft query
    Hi
    I just took my car down to the mechanic and he told me when he looked under it that the tailshaft was sitting on an angle! Is this how it should sit or should it be completly straight.
    The centre bearing in mine was shot so I went out and got another and put it in the same way it came out, but it still sits on an angle. PLEASE HELP!!
    Thanks
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    If the car is on stands and the solid rear in hanging down, the rear half will be at an angle. Sitting on it's wheels it's more or less in a straight line. Dunno about IRS but I'd imagine should be in a straight line whatever.
    Dumped IRS VS Acclaim 3.8, VR Stato Caprice 5.0
    Nov 2007
    Hatton Vale. country at its best. :)
    irs still sits in a straight line..
    gees, where are yas all gettin this crap talk from??
    i have just put my car back on the road, and the arrow on the centre-bearing points, TO THE FRONT....
    it has to point to the front, due to the angle of the tailshaft, otherwise, u will chew the bearing apart..
    irs, and live axle[solid] are pretty much the same tailshafts from vn-vs sedans..[manuals ARE different]
    wagons are different also, due to the longer wheelbase..
    if the car is on the ground, the t-shaft sits nearly inline,
    and when raised, it flows downwards due to the axles being raised off the ground..
    if ur that worried about the bearing, get another new one,[ 50 if i remember from repco] and get a GOOD, and WELL KNOWN MECHANIC to replace it for ya..
    if they are good enuff, they might even rebalance the shaft to ensure their work, and no vibrations..
    Nov 2007
    LS6
    LS6 is offline LS6 Executive
    VQ Statesman
    Dec 2010
    Default 5speed statesman
    I remember years ago a mechanic pointing this out to me. i had the bearing replaced by one other mechanic then i took it to another for something else and thats when he pointed it out to me that the centre bearing was put in wrong that the tail shaft is on an angle. Till this day im not sure what the story is.
    So If anyone has any answers if the arrow should be facing forward or back on a manual vq statesman. Please let me know.
    vs commodore
    Oct 2009
    Tamworth NSW
    The VS gregorys manuals says: Ensure the bracket is fitted the right way around.On models with conventional rear suspension,the arrow with 5LK must point towards the front.On models with Independent Rear Suspension,the arrow with IRS must point towards the front.Id say the VR would be similar to VS.
  15. #15
    immortality's Avatar
    immortality is offline crappy ol' VN driver immortality W427 immortality W427 immortality W427
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    Quote Originally Posted by Brett_jjj View Post
    this is correct caught me out once
    Body by Holden, Soul by Brock
    the Legend will live forever
+ Reply to Thread
  1. CAI query
    By MJR_VR in forum General
    Last Post: 04-04-2007, 03:26 PM
  2. VS Diff wanted and tailshaft query
    By sixes in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-06-2006, 09:17 PM
  3. VH query
    By spd_dmn in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 15-10-2005, 08:03 PM
  4. Query
    By breast69au in forum VY Holden Commodore (2002 - 2004)
    Last Post: 07-04-2005, 09:13 AM
  5. VN Query
    By mephisto in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-08-2004, 09:54 AM
