head lights!
daniel VR
VR Acclaim S2
Hi guys, just a quick questions. A mate of mine gave me a pair of Halogen H4 12v 90/100W. Are these suitable for my vr? Or are the watts to high?
cheers.
jafo
lurker since 2003
59
adelaide
1999 wh statesman
dunno but thats a bit bright for low beam so i'd be careul using them incase its illegal
daniel VR
VR Acclaim S2
thanks mate! any one else know?????????????
statement
reaching new limits
north but not to north
VY/VZ Calais/Tonner
i had 50/100 watts in my old vn an had no problem untill i change the highbeam to 100watts as well then i started to blow fuses but for just the h4 i never had a problem
mattman
'00 WH V6
Too bright mate... you'll burn something out :S
kopper69
VRII Acclaim
You need to know what the stardards use. If you are putting in a bulb thats going to suck the power you will blow fuses and put pressure on relays (maybe). Could be illegal too if they are too bright.
VLishes
BaZMeG
47
VS Calais SII
I had bright bulbs in my VL years ago and my fuse melted, wires were a bit soft and the bulbs use to pop.
MrTinky
VE SS
I was told by a auto electrician that using anything above standard will help to fade the reflectors faster because of the heat generated by the brighter lights.
