P
Pauly2478
Guest
ok guys heres the VR CAI
now, before you start your guna have to take out the windscreen wiper bottle, if u dont wanta then stop readin, ok.
Important to disconnect ur Battery!
Take out windscren water resoviour!
1st thing go buy ur self a 300mm long x 90mm diamention piece of drain pipe along witha 2x45* bends, also some pluming blue glue stuff oh and zip ties.
2nd cut a hole in the bottom of the airbox (no if u look closely there is a 90mm circle already there so u dont have to measure.
3rd now place ur air box in the original position in the car and measure the hole to be cut in the metal, :whistling ,this is the fun part.
4th once ur have measured 90mm then either get a drill and drill losta holes or pay sum1 to do it (personally i drill a million little holes)
5th once ur done there put ur pipe in the hole to c if it fits and if it doesnt keep drilling:bang:
6th once all drilled out and sized up, put pipe in both holes(ensure a tight fit)
7th glue pipe in to air box then glue 45* angle on other end.
8th zip tie 45* bends to bumper bar harness and away u go! (after u reconnect the battery)
any way thats it i think if i remember, the only reason i put this up was i couldnt find steps for a VR CAI.
if i 4got ne thing plz tell me
pauly
pauly
