Results 1 to 9 of 9
Thread: Engine stalls when cold
    bnorton Guest
    Default Engine stalls when cold
    my vs commodore has been having problems when the engine is cold. In the mornings it has problems starting the engine and when it does the yellow engine indicator illuminates whilst driving along and cuts the engine.
    After a few restarts of the engine the car runs smoothly and can then be restarted without any major hassles. Upon inspection, the RACV were concentrating on the DFI module but they could not diagnose 100% and suggested checking the computer for error codes.
    DJ Majah's Avatar
    DJ Majah is offline Electro doof doof styleé
    VSII cruiser
    Jan 2004
    Brisbane - Ipswich
    natsvr Guest
    The yellow light is the EMS (engine management system). My guess is it's a sensor, but not sure.
    bnorton Guest
    I believe its the yellow drivetrain light which comes on. Once the engine has been running for at least 5-10mins it seems ok, but before that lapses the drivetrain and battery lights come on.
    Feb 2004
    did you check the engine codes? what codes did you get?
    just incase you didn't knowhow to et codes these links will show you how to extract codes and what they mean.
    Extracting codes
    VS codes (V6)
    bnorton Guest
    The codes displayed from the computer were 46 & 47. Would this be a crank sensor ?
    Feb 2004
    Yep! thats your problem , a common problem on both VR/VS part cost $100 form holden takes about 30 -45 min to change
    Gavin
    bnorton Guest
    bnorton Guest
    Smile
    Confirming that the CAS was the fault, thanks for your help guys !!
  1. engine stalls while driving
    By tomw83 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-01-2010, 09:37 PM
  2. Engine stalls when put into Park.
    By mischf in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-08-2006, 12:42 PM
  3. VS stalls approx 15min after cold start
    By Trevor Johnson in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-04-2006, 06:14 PM
  4. Engine stalls and engine light comes on.
    By tysons_2001 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-03-2006, 08:01 PM
  5. VN stalls after taking a corner when cold
    By nole in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-07-2005, 10:22 AM
