Results 1 to 15 of 15
Thread: power lvl
    statement's Avatar
    statement is offline reaching new limits
    VY/VZ Calais/Tonner
    Jun 2004
    north but not to north
    Default power lvl
    hi guys, last week a got my new 2 1/2" cat back exhaust fitted (very happy with the note) but i'm a little worried that its not making the power it should? i had it dyno after it was fitted an it makes about 140hp at the rear wheels, would that be right?
    the car is a vs statesman V6 with no other mods an about 300,000kms. i'm a little worried cause i seen other people v6's make more power stock like 150 plus(on other forums) or so they say
    can any one help with my question?
    cheers
    in life some people need a little guidance, others just need a good kick
    bonglung Guest
    My old VR V6 motor pulled 140.9RWHP with a 320,000k ex trashed cop motor. Was down badly on compression on one cylinder and the most if not all the valve guides where screwed. Use to be a prick to start with a cloud of black whereever I started it, but it use to rev so damn quickly. That was with a 5speed too. Mods at the time were CAI, Standard Air filter, removed bellmouth, extractors, hi-flo cat, 2 1/2" system.
    Now i've got a nice VP motor in there and everythings running like a dream. But I haven't had it dyno'd.
    So in answer to your question, if my old tired screwed motor could pull 140RWHP, then you'd think a healthy motor would get above it? *shrug*
    bonglung Guest
    Oh wait, didn't realise you had a Ecotec VS.
    Give it a good major service and go from there, could just need a new set of leads or something simple holding you back. Or the motor could just be on it's way out.... 300,000 is getting on a bit.
    VZ LS1 Calais
    Dec 2005
    South Brisbane
    that doesnt sound all that bad for a motor with that many k's on it.
    i think its also a very common misconception that adding a cat back (or exhaust work in general) system will give you all this extra power and torque..when the performance improvements are really only marginal.
    combining exhaust work with other simple bolt on mods can also improve the overall performance when working in unison.
    oh, and what bonglung said about leads... a competent dyno place would have run checks on leads and plugs, checking the resistance and so-forth.
    statement's Avatar
    VY/VZ Calais/Tonner
    Jun 2004
    before the new exhaust it ran about 120-124hp, the leads aren't that old maybe 6 months(top gun 8mm), but i have a feeling its either the sparks or the coils cause i had problems with the dis module(i think that wats it called, it sits under the coils) but now i'm just saving up for my new motor then i'll have no problems with power
    thanks for all of your imput guys
    bonglung Guest
    Depends on the dyno place and if it was a dyno day and so on. But if it was just a power figure he was chasing they would of just strapped it, ran it printed out the sheet and asked for some dosh.
    Instead of just buying another stock (second hand or rebuilt) why don't you spend the little extra and have yours rebuilt with the go fast bits.
    Plenty of proven engine internal combos to search for.
    If you're that keen, buy a come ecotec stroker short block and put your stuff on it, i.e heads, manifold and so on. Obviously would want to freshen up your heads and whatever your transfering over.
    Just something to add to your thoughts.
    statement's Avatar
    VY/VZ Calais/Tonner
    Jun 2004
    yer i thought about rebuilding my motor but i decided on getting a s/c 6 with come's 4.2lt crank and FIT's boost pulley upgrade an some hiddens extras i'm hoping in about 2-3 months i'll have the motor ready
    VZ LS1 Calais
    Dec 2005
    South Brisbane
    Quote Originally Posted by statement
    (drooling)..that would be super sweeeet man. exactly the sort of thing i would do on my car if i had the dosh...just to be a little different (instead of goin v8 or normal s/c 6) a supercharged 4.2L stroker, sh*t yeah.
    lets us know how she goes when you get it all setup.
    TheForgotten's Avatar
    TheForgotten is offline only human......
    VR EXEC
    Dec 2005
    quarantine
    *cough* wipple *cough*
    Quote Originally Posted by MY-42-VT
    if they didn't have that thing between there legs we'd laugh and throw rocks at them
    WTB VR/VS FACTORY HEADUNIT BRACKETS PM ME
    statement's Avatar
    VY/VZ Calais/Tonner
    Jun 2004
    Quote Originally Posted by TheForgotten
    r u talking about superchargers?
    VR EXEC
    Dec 2005
    quarantine
    yep. COME stroker with a wipple on top. they sound f'in nuts even on a sixpot.
    from what I understand, they'll put out more power (than the m90) at lower rpm due to running cooler
    statement's Avatar
    VY/VZ Calais/Tonner
    Jun 2004
    thought so, will have to wait an see wats happens, in the end i'm hoping for about 550-600hp at the flywheel then i should have no problems with keeping up with the gen3 boys(an girls )
    VR EXEC
    Dec 2005
    quarantine
    without serious blower porting, there's no way in hell you'll get that with the m90, and the wipple is too "young" to get reasonable figures for the v6 just yet, but for that kinda power, you'd be better off with a turbo over a s/c
    VS SIII CAPRICE
    Feb 2006
    vic
    cheers
    140hp is pretty good man. What exhaust is it and how much was it?
    Thanks
  15. #15
    statement's Avatar
    VY/VZ Calais/Tonner
    Jun 2004
    it was a lukey 2 1/2 inch cat back, 1 muffler an a straight pipe at the back with tips, all up it cost me $400 thats for muffler, tip an dyno run an i gain around 20hp from stock
  1. Options..power seats... power windows??
    By Hairy Eater in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-01-2010, 05:01 PM
  2. Desperatly Seeking Power + Power + More Power
    By kezza_4246 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-10-2007, 09:28 PM
  3. need more power
    By kezza_4246 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 23-09-2005, 08:15 AM
  4. POWER - Real Power
    By MattK in forum V6 Development And Modification
    Last Post: 01-05-2005, 04:10 PM
  5. more power u might help me with
    By Rumbl in forum V6 Development And Modification
    Last Post: 24-01-2005, 08:56 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
