A
anotherstockvs
Guest
i use 10w/30 in my vs the oil is to thin and it jus burns it so after hangin hoops on the limiter it started knockin noticed the oil was down a little so i thought id drive it home top it and shibby rite but it didnt go away but then real bad grinding noise came so i replaced the harmonic balancer which fixed the grindin noise but didnt fix the knockin it starts fine idles like a champ but a slight knock can be heard at 1500rpm and it gets real loud and superfast at 3000rpm kinda like a bolt jumpin around it can be heard the worst directly over the plenium chamber but its defintly not rocker or lifter or valve related its not the counter balance shaft at fault cause if it was smoke would jus pisses out the oil cap, its really got me quite stuffed, like i dont really wanna pull the head off and investigate and ideas ppl i need sum
cheers ImI<(^_^)>ImI
