Results 1 to 9 of 9
Thread: how does the ecotec engine idle?
    VS sedan and a VK DRGWGN
    May 2004
    darwin
    Default how does the ecotec engine idle?
    How does the ecotec (or really, any EFI engine) idle?
    I pulled the intake pipe off to clean out the throttle body in an attempt to make the car run properly, and noticed that when the butterfly is closed, no air can get past it.
    How does the engine idle then?
    ECOTEC KICKED IN yO!!!!!!
    VP Executive R-spec
    Jan 2005
    There's a thing called thr IAC Idle Air Control Valve that opens and closes to let air in that hole in the side of the throttle body
    May 2004
    darwin
    ahhh, thanks for that.
    how do i know if it is working? the car is having real issues starting and idling. the throttle body isn't that dirty, so i think it might be somethign else.
    VS Commodore Acclaim
    Jan 2006
    Idle speed is controlled by the crankshaft sensor determining counts or pulses from the crankshaft which is fed to the ECU. The ECU will then control the IAC valve when the ECU senses that the throttle is closed (switch on the throttle shaft). The IAC is a servo valve with a stepper motor that opens or closes a bypass valve which bypasses the butterfly.
    What can go wrong?
    The IAC valve can get clogged with engine vent fumes solidifying in the passage and causing the IAC valve to stick.
    The throttle switch can become faulty (intermitent or not work at all).
    The crankshaft sensor can become faulty which misses some of the counts from the crankshaft pulley.
    An air leak into the manifold from a broken hose or such like.
    Usually if everfything is working OK, holding the revs at about 3000 for about 30 secs should allow the idle valve to reset and if the engine is brought back to idle it should be OK. If not check out the items above and if they are OK check wiring connectors. It is also possible for the ECU to be faulty. The Gregory's manual has a good section on trouble shooting this area.
    May 2004
    darwin
    hrmmm. the car is weird. It idles fine on petrol, but switching to gas it dies. If i keep the revs up, it is fine, it just wont' idle on gas. It is a factory gas install. I noticed there is a screw on the gas mixer with idle written on it.
    should i touch it?
    '96 VS ACCLAIM (duel fuel)
    Sep 2005
    May 2004
    darwin
    Quote Originally Posted by futronix
    gas system might need a tune.... if there is such a thing.....
    yep, gas tune.
    anyone know how to do one!!??
    2004 VY2 SV8 A4
    Jun 2005
    Victoria Point, Brisbane
    I imagine when messing with gas it would be a better idea to take it to a specialist...
    * Phreddy's Blaupunkt Aux input and line out mod
    * 18x8 inch Equus Kalibur Wheels with Maxxis MAV-1 235/40R18
    * Sureflo 3.5 inch medium-loud cat back exhaust
    VY SS Wagon
    Mar 2006
    That screw is for mixture adjustment which should be done with the aid of a gas analsyser. good chance your convertor or mixer is stuffed.
  1. ECOTEC idle problem
    By syk35 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-01-2011, 11:24 AM
  2. Fluctuating idle on deceleration in 3.8 V6 auto (ECOTEC and non-ECOTEC)
    By cliffo78 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 25-04-2009, 12:02 AM
  3. ecotec idle speed adjustment
    By Panama in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-10-2007, 08:17 PM
  4. Ecotec Stumble off idle.
    By squidda in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-07-2006, 11:34 AM
  5. VT V6 Ecotec Idle Revs Range
    By iamset69 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-12-2005, 10:58 AM
