thats right but you have to turn the key on but dont start it. let it sit for a min then turn it of and put the fuse back inCHANDLC said:pull out engine fuse leave out for aprox 1 min then replace and all should be well thats if it is a VS
mattman said:Disconnect the battery and hold the brake pedal on fully for about 1 min... leave it unhooked for about half an hour "just to be sure" and you should be good to go... it might take a couple hundred k's to relearn but you should be runnin sweet after first refill.
