Starter Motor Wiring
HsvMan
37
VS Executive V6
Hey guys
My car (VS V6) wouldn't start yesterday, got the RAC around.
It turns out the starter motor wiring is faulty.
The starter motor is pretty hard to get to, unless you jack it up and get under it.
My question is - is the wiring easy to fix for the average person? or should I just get a mechanic to do it.
I haven't checked the wiring yet, so I'm not too sure what it all looks like
Any suggestions on how to fix it?
I sorta need the card for Monday :)
markovr
62
northside brisbane
youtu.be
07vessv 94vr .04vz wgn,93vp wgn,82 vhV6 wgn 88 vn
What part is stuffed?Is it the big positive that actually powers the starter or the some part of the control that pulls in the solenoid including the start relay ,ignition switch and neutral safety switch?
It is common for the ignition switch contacts to stuff up and the car wont start or the keyhead not to be read by the contact.
HsvMan
37
VS Executive V6
I'm pretty sure its the "big positive that actually powers the starter"
The RAC guy jiggled around with the wire while I tried starting the car.
Started fine. so yeah
HsvMan
37
VS Executive V6
Yup, definately the main wire to power the starter motor
Just started the car then, while someone was jiggling the wire
markovr
62
northside brisbane
youtu.be
It comes straight from the battery so its gotta be a loose lug or the male terminal of the starter motor solenoid loose or broken.If its broken or if it has a high resistance the starter motor will have to come out and whatever is wrong fixed.
If the main power wire lug is high resistance or wire broken it will be a matter of relugging making sure you dissconnect the terminal off the battery before doing anything for safety.
markovr
62
northside brisbane
youtu.be
There is a smaller wire with a female spade type terminal that comes from the starter relay that is violet/white that is in the same loom as the big positive wire that might have a hight resistance.
Also the big red heavy wire has a lug that has a hole in it that a stud terminal on the starter motor solenoid goes through and is done up by a nut...so you could check the tightness of this terminal on the starter
VT clown
39
Darwin
VT
Hey everyone got a vs v6 just wanted to no if any one could help me with what wires go on the terminals as I have the positive one sparked and smoke thanks
BlackVXGTS
Melbourne, SE
Did you read the previous post (#6) before you asked your question?
VT clown
39
Darwin
VT
Na mage I didn't as first time ever being on here
