Results 1 to 9 of 9
Thread: VS Clubsport Problem!! HELP!!!
    weedo_86's Avatar
    weedo_86 is offline JC Resident FireFighter
    03 VYII Clubby M6, 92 Barina With Sunroof :)
    Feb 2006
    Melb, Vic
    Default VS Clubsport Problem!! HELP!!!
    Latly i have been getting a crackling noise from under the car it sounds like stones are hitting the bottom of the car, when under a bit of throttle sumtimes doesnt matter if its hot or cold it makes the noise from the middle section of the car, i have had a new redback exhaust installed from the cat back, i thought that may have been the problem but the noise is still there, it is really irratating me.
    Any advice guys thanx
    2003 BA XR6
    Apr 2005
    maybe ur cat is stufd, my cat made that noise when it went on my vp.... rattle/shake it a bit when engine off see if u can hear same noise...
    VS V6 TwinTurbo/VT SS Manual
    Sep 2005
    1996 VS Clubsport S2
    Feb 2012
    Frankston
    I would say that your catalytic convertor is stuffed but it you don't have the money to fix it then just turn up the stereo and drown out the noise. Cheers.
    muttley383's Avatar
    muttley383 is offline Donating Member
    VR 383
    Sep 2007
    Have a look along the front seat mounting points from under the car to see if you have any cracking or splitting of the floor around the tunnel.
    I have seen a VR floor pan crack from the drivers side rear inside mount and travel half way along the tunnel. The crack was about 250mm long.
    muttley383
    vs calais 355 supercharged
    Feb 2012
    gold coast
    My money is on cats... I've had them go before an it's a terrible sound..
    SS
    Jan 2012
    Australia
    GTP 85's Avatar
    GTP 85 is offline 291 hp @ the wheels
    VS track car & VS SSenator
    Aug 2006
    Adelaide, near the bay
    Lol. This is an ancient thread guys....
    Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
    GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
    Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    Quote Originally Posted by GTP 85 View Post
    One would hope after 6 years it would be fixed.
  1. 1993 Hsv Clubsport Starting Problem
    By hldngrlnz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-10-2007, 02:04 AM
  2. Pt 2 cold starting problem - Is my ECU the problem??
    By manfred in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2007, 09:56 PM
  3. MY VS Clubsport
    By vs_clubby in forum VR - VS
    Last Post: 28-04-2007, 11:46 AM
  4. Vr Clubsport Problem
    By Disturbed_vegeta in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-05-2006, 06:31 PM
  5. VX Clubsport kit
    By donz in forum General
    Last Post: 04-09-2005, 04:43 PM
