Page 1 of 2 12 LastLast
Results 1 to 25 of 47
Thread: Super Charger for V6
    CHANDLC's Avatar
    CHANDLC is offline BushBasher
    1996 V6 VS LEXCEN
    Mar 2006
    TOWNSVILLE
    Talking Super Charger for V6
    Has any one bought the bolt on super charger from the rod shop, if so how dose it go.
    GO HARD OR GO HOME
    check out my ride
    http://forums.justcommodores.com.au/...ad.php?t=33118
    TheForgotten's Avatar
    TheForgotten is offline only human......
    VR EXEC
    Dec 2005
    quarantine
    many people have them. can't say how they go from experience, but stacks of people have them. I guess they aren't bad for the money, but if you're after gobs of power/torque, save more money and buy a real blower
    Quote Originally Posted by MY-42-VT
    if they didn't have that thing between there legs we'd laugh and throw rocks at them
    WTB VR/VS FACTORY HEADUNIT BRACKETS PM ME
    Tradewind Guest
    If the CRS is as far as you can stretch in $$ terms and you aren't prepared to save any more then get er on. Don't expect too much action but you will be able to proclaim "this baby is blown"
    VS V6 TwinTurbo/VT SS Manual
    Sep 2005
    medz84 Guest
    what are these kits worth? also what power are they making in stock 6s? im doing the whole budget thing also were is the rod shop ?
    medz84 Guest
    VROCIOUS's Avatar
    VROCIOUS is offline Searching for more HP
    VR SS
    Sep 2005
    Perth, Western Australia
    VS Executive
    Oct 2005
    well I'm planning on getting this kit:
    http://www.capa.com.au/kits_holden_vnvy_v6.htm
    costs a bit but hopefully it will make me happy I'm going to order it Friday.
    harro_VR is offline Boosted VR
    vr Berlina turbo, VZ SS
    Aug 2005
    Hervey Bay
    Tradewind Guest
    Yer Stage 2 looks hot hey, are you gonna dyno it after you fit it? Boosted V6
    There is another fella on this forum his ute goes pretty well, he has different system, could be cheaper by a good bit too. Check with him he could tell you the ins and outs
    266rwHP Supercharged VS Ute
    2004 VY2 SV8 A4
    Jun 2005
    Victoria Point, Brisbane
    You can not safely give a standard ecotec motor more than about 6psi of boost. If you do, theres a good chance something very very bad will happen, ending in about $5000 worth of engine rebuild.
    If you get the CRS kit or similar, you'll put 3psi into it, or with their smaller pulley, 6psi. This is a good bet if your budget is limited.
    If you want MORE POWER (who doesnt hehehe) you might like to consider dropping in an L67 motor from a factory supercharged VS Calais, VT or WH Stato for example. This is what I am planning to do with mine and I found a place that has one from a WH Stato for $4400 complete. The standard L67 runs about 7 or 8 psi of boost and the internals can handle 12 pounds constant and even 17 psi for short periods such as a day at the drags.
    FIT make an excellent selection of modifications for the L67 including an assortment of different pulleys to provide varying boost pressures and the best thing is that these can be changed in 5 minutes with a 15mm ring spanner and a phillips head screwdriver.
    Check out http://www.v6supercharged.com.au and FIT's videos may convince you to extend your reach that little bit extra. Quarter mile times in the 12 second range aren't that far away after all!
    If an engine swap sounds hard to you, never fear. There are plenty of people on the forums who will help you at the drop of a hat for the pride of a job well done and a carton of beer.
    * Phreddy's Blaupunkt Aux input and line out mod
    * 18x8 inch Equus Kalibur Wheels with Maxxis MAV-1 235/40R18
    * Sureflo 3.5 inch medium-loud cat back exhaust
    VS Berlina S2
    Sep 2004
    Hey Guys/gurls.
    Im in SA and we arnt allowed to strap on an aftermarket s/charger or turbos.
    How is it that the other state are allowed to?
    If we (SA) abide by the ADR's what allows you guy/gurls to change emmison rules?
    Is there any info via interstate transport websites?
    Slammed VS Berlina
    Mar 2006
    Quote Originally Posted by medz84
    www.rodshop.com.au the kit is $1950 and $400 for the extra small drive pully.
    VS V6 Ute 5 speed 221.48rwkw
    Feb 2006
    Maryborough,QLD
    If you after a good Aftermarket SuperCharger at a good price that looks good and deliveries heaps of power for stage 1 have look at www.raptorsc.com.au with a stock internal motor with a Raptor Supercharger mounted on side with 8.5 psi am pushing 274.5rwhp.
    221.48rwkw Raptor Supercharged VS Ute latest dyno run as of 04/08/07
  15. #15
    Tradewind Guest
    Clinster
    You have the biggest aftermarket blower retailer in your state CAPA, there would be plenty people in SA fitting blowers. You should check out how its done there, ring em up for 1st hand advice.
  16. #16
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    Quote Originally Posted by clinster73
    Hey Guys/gurls.
    u on drugs mate?????? all you need is an engineers certificate.....
  17. #17
    2004 VY2 SV8 A4
    Jun 2005
    $4990 for the stage 1 kit? I'd rather drop in the L67 and whack a smaller pulley on it. Can get complete motor + box + ECU + loom all for $4400.
    Still, if an engine swap sounds daunting then the raptor SC sounds like a good deal!!
  18. #18
    Tradewind Guest
    How much FIT mods would you need to make the L67 pull 275 on the tyres?? Prolly another 2K at least to get it up around 15psi etc etc etc even an intercooler maybe. Tuddles has a thread on the other big street commodore forum and he flogged a whole bunch of em with FIT mods on em
  19. #19
    VS Berlina S2
    Sep 2004
    Quote Originally Posted by boona15
    No unfortunately its not that easy...
    You cannot fit a aftermarket turbo/supercharger to any ol V6/V8 fullstop with or without an engineers certificate.
    The reason why i know coz me mate got defected for it after spending $6000 on his set up!
    I only know of one CAPA vortech blower that is allowed to be fitted but thats to a Gen111 only.
  20. #20
    VS Berlina S2
    Sep 2004
    Quote Originally Posted by Tradewind
    Clinster
    yeah i know they are in SA and Sa it seems to be the only state that doesnt allow aftermarket turbos/blowers!
  21. #21
    vs commodore sedan
    Jul 2005
  22. #22
    2004 VY2 SV8 A4
    Jun 2005
    It's actually not that expensive to get an L67 to pull 275 at the tyres... For $860ish you can get 2 different pulleys for it and it will handle up to about 17 pounds before you even touch the internals.
    Now the ecotec, however, you'd have to do a LOT of work to it to get it to that, as tuddles has already done with heads ported, bigger TB etc etc, but for a stock motor it would take a lot of money. The stock L67 requires only a smaller pulley and can be intercooled for only about $3k as well. Much better spent than spending $4-5k on rebuilding the ecotec just to handle the amount of boost the L67 has stock.
    Not to mention the trans is stronger in the L67 also, so no need to strengthen it, which would cost a couple of grand also.
  23. #23
    VT
    Apr 2005
    QLD
    Quote Originally Posted by shaggerz
    Sounds all well and good, but if you are pushing 17psi out of an M90 eaton supercharger, that air is going to be superheated. mad. look at the application and compare the two different types of supercharger. the eaton is a positive displacement blower, good for consistent low down power, not much chop up top, especially if you are over spinning it on a big(ish) 3.8L engine. the raptor job is a centrifugal setup with much better efficiency at higher rpm due to the design of the blower. if you strapped an eaton to a N/A ecotec vs. the raptor kit, i know what my money would be on.
    my 2 cents.
  24. #24
    2004 VY2 SV8 A4
    Jun 2005
    You are right about that, and if there was no budget limit, the best thing to do would certainly be to rebuild the ecotec and charge that with an intercooled centrifugal blower.
    For the money though, I personally will be going with the L67. Estimated cost for L67 conversion with 17 pounds and big sodding intercooler? $4400 for a wreck and $5945 for FIT's ultimate pack. So for a total of $10345 we have the following:
    Factory supercharged V6 with...
    * Eaton M90 pushing 17 pounds (your choice of 2 pulleys)
    * Intercooler + all plumbing
    * 3 inch mandrel bent exhaust
    * 1.9:1 Rockers
    * 81 degree thermostat
    * cold air intake
    * boost gauge
    * heat shield
    and a heap of other fun stuff. Theres no need to go to this extreme of course, but all this can be done without even opening the engine, and the total output power? about 270kw at the wheels. To achieve that with an ecotec, you'd spend the same money on rebuilding the motor and purchasing the blower, let alone adding intercooler, etc etc.
    Everyone will have their own strategy of course, but thats the logic behind mine. I am willing to spend a bit more money to make sure I have the potential to push the existing configuration further should the need arise.
  25. #25
    shamden22 is offline shamden22
    vr executive
    Mar 2006
    traralgon
    its all good to go into detail about boosting your ponys but does anyone put any thought into the fact your drive train is not upto the job if it was once a stock v6. its gonna get real expensive with a new box and diff
    dont justify the truth by lying
  1. Eaton M90 Super Charger
    By saint_matrix in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-06-2006, 03:52 PM
  2. Super charger
    By Sensations in forum The Pub
    Last Post: 15-02-2006, 03:29 PM
  3. super charger ....... possible?
    By pheonix in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-10-2005, 10:56 PM
  4. Super Charger Vn Calais
    By shane0o7 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-06-2005, 10:55 PM
  5. Little Jap Super Charger
    By freckly in forum General
    Last Post: 11-02-2004, 06:09 PM
