hako said:
Consider how long you are going to keep your car....maybe a year or two then you're throwing your money away using expensive synthetic oil. Keeping the car till it dies (10yrs?) then maybe use synthetics but make sure you extend your oil change periods to take full advantage of the synthetic. By the way, synthetic is made from mineral oil base...its just 'altered'.
Another thread about engine oils... One of my fav topics:thumbsup: There's this idea going around that if you use synthetic oil you can extend the length between oil changes... Total bollocks! You should still change the oil by the book which is maximum of every 10,000k's. Many people change their oil every 5000k's and tend to get many more years out of their engine, myself included. Also synthetic might be made from a mineral base, but all those particles that remain in a mineral oil are refined so I think it a little more than just "altered".
I owned a VS exec until this February and I'd racked up 384,000k's. Apart from a whinning diff, the engine and auto transmission we're totally original in near perfect condition (apart from the engine using a fair bit of oil but it ran smooth as). It has always had Castrol GTX2 (full mineral oil) changed about every 5 or 7000'k. At 5000k's the oil had turned pretty thick and black. Now with my S/C VS calais I'm running Mobil 1 10w/30 and nearly 5000k's since I bought it and serviced it the oil is still looking good and the car is running great. You might not want to use such a thin oil as I do but I have no regrets switching to full synthetic. On my old exec under the oil cap, there was a build up of hardened burned oil deposits. Obviously that same build or deposits would be in the engine too. But you won't tend to get those harmful deposits with synthetic.
One other thing is if you do decide to switch to synthetic is to change the oil, run it for about a week and then change it again. That way you'll be sure to get as much of the old crap out. I did that with the Calais when I got it and even the 2nd time I changed it after a week there was still a lot of black crap that came out with the new oil. That way the engine has been fully flushed. The first time you may want to use a cheap oil. Some people have their own ways of doing it but thats mine. Do a search on 'synthetic' oil on this forum and you'll find a few threads on it.
