Originally Posted by
shanhsv
My driveplate has shat itself and im not sure how to take off the gearbox so i can replace it,can any1 help
Prick of a job to do...
first disconnect the battery
then drain the trans fluid
remove the trans lines from the auto
undo the filler tube to the trans and plug the hole into trans with a rag
remove catalitic conver / exhaust
remove the starter motor
remove the tailshaft
remove the shifter linkages / speed sensor and any wires
remove the torque convertor cover plate
undo the torque convertor bolts to drive plate (you'll need to rotate the motor to undo them all)
undo the trans crossmember
while supporting the trans with a trolley jack
undo the bolts mounting the trans to the motor
take the trans and torque convertor out together
then you can undo the driveplate
It's a big job I wouldn't recommend a noob do it either as there is so much that could be stuffed up... it would be easier/ less stressful to pay a mechanic to do it !
Disclaimer For The Reader ::
The information I provide is freely given to ONLY help you with thinking on problem solutions. IT IS NOT a "How To Do It Guide".
If you read ANY of my supplied information and use ANY of it you must accept and agree to do so AT YOUR OWN RISK or do not use the information at all.
I accept NO liability if you damage your or anyone elses property or cause any harm to yourself or others with the information provided.
I am NOT a Mechanic. You have been warned.
