Swapping cam in VR VS V6 ?
sixshooter
2x VS
Has anyone here done a cam swap on an Ecotec ?
I'm curious if it can be done without lifting the block out... there looks to be enough room with the radiator & fan taken out to do it in.
TIA
NeilB
65
VR Caprice
Your right, if you remove the fan and rad you can do it, you can get better room if you also remove the front bar.
sixshooter
2x VS
Thanks Neil !
