Results 1 to 6 of 6
Thread: Cigarette lighter not working
    95 VS Vacationer
    Jun 2005
    VIC
    Default Cigarette lighter not working
    I took the centre console cover plate off, and its connected, the light works, but the actual lighter thing isnt working. I dont smoke, but i bought a little spider thing to put in the lighter thing, and it didnt work, then i tried to use the actual lighter, and it didnt heat up. What would be the usual cause?
    VRII Acclaim
    Jul 2005
    First check the fuse, make sure that hasnt blown. If you were playing around you may have just shorted the circuit and blown it. Next you could remove the dash and make sure that you have 12V there. I can help you out further if you find out about the 12V.
    95 VS Vacationer
    Jun 2005
    VIC
    jafo's Avatar
    jafo is offline lurker since 2003
    1999 wh statesman
    Yetisports 3 - Seal Bounce Champion!
    Oct 2003
    adelaide
    the fuse is under the steering colum in the fuse box right at the end no15 from memory
    also check the wires have not come off the back of the lighter as my black wire came off was a pain in the ass to fix
    three thing in life are guaranteed
    taxes
    death
    and car repairs
    Vs_sharlene's Avatar
    Vs_sharlene is offline Beats a Kick in the Face!
    VSII Executive
    Dec 2005
    Yea I had the same problem, lights but no lighter
    Turned out that it was the fuse and wiring (disconnected from actual lighter)
    Fuse is easy to replace, on vr/vs they're on the right, below the steering column, there is even a little map to show you which fuse is which. (5 pack of 5/10 amp fuses $2)
    Wiring is a bitch, bloody near impossible to solder (but still possible) or use electiral tape
    95 VS Vacationer
    Jun 2005
    VIC
    Yeh thanx guys, straight after i asked the question i figured it out, and it was the fuse thank god. I just stole a fuse outta my brothers old car and put it in and its working
  1. Cigarette lighter in VT
    By Travelling Phil in forum Electrical Wiring / Questions
    Last Post: 25-07-2011, 09:41 AM
  2. cigarette lighter fus
    By vg91ute in forum Electrical Wiring / Questions
    Last Post: 02-01-2008, 08:12 PM
  3. VS 12V cigarette lighter not working (no voltage)
    By catalyst55 in forum Electrical Wiring / Questions
    Last Post: 10-06-2006, 09:36 PM
  4. Cigarette Lighter working
    By Denno in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 22-02-2006, 10:59 PM
  5. cigarette lighter not working
    By ucwepn in forum VL Holden Commodore (1986 - 1988)
    Last Post: 11-08-2005, 08:43 PM
