+ Reply to Thread
Page 1 of 3 1 2 3 LastLast
Results 1 to 25 of 57
Thread: Removing Black Rubber Side Strips
    Slow VR's Avatar
    Slow VR is offline Another White Crummodore Slow VR Executive
    VR Series II
    Apr 2006
    Cairns, Nth Qld
    Default Removing Black Rubber Side Strips
    I am thinking about attempting to remove the black rubber side strips along the doors and gaurds, i was thinking about using dental floss in behind it to cut the rubber then clean it all up with wax n grease remover.....???
    Any1 got any better suggestions or know of any tricks or hazards??
    Cheers.
    VZ LS1 Calais
    Dec 2005
    South Brisbane
    search is your friend...there's lots of reading to be found on this, so have a geez at some other threads too.
    the basic rundown is that the door moulds are held on by double sided tape and sikaflex...ive found just pulling them off (very slowly so you dont warp the door skin) is the easy way to do it, use a applicator to "cut" any sikalfex that wont come free from the mould.
    tidy it up by pulling off any excess you can, then use a pin stripe remover/caramel wheel to take off all remaining sikalfex...finish off with wax and grease remover.
    just take it easy in ever step, patience is needed, you dont wanna get carried away and mark the door skin.
    VE2 SS Voodoo
    Jul 2005
    ey mate, i did this a couple of weeks back, its pretty simple, but just time consuming!
    anyway, just follow what sircruisealotVS said, have a bit of pacience, use something to but the sikaflex(that stuff is a bitch to get off even with a caramel wheel) and itll be sweet.
    u might get a few small areas that the sikaflex takes the paint off so juz be careful.
    ALSO! if your paint is acrylic based DO NOT USE A CARAMEL WHEEL! as it will strip the pain right off! only use the caramel wheel if you are sure that ur paint is 2pac.
    attached is what mine looks like now.
    Nick
    Attached Thumbnails Attached Thumbnails Removing Black Rubber Side Strips-img_0377.jpg   Removing Black Rubber Side Strips-img_0380.jpg
    semi is offline GOD semi Berlina
    VR exec wagon
    Aug 2005
    WA
    slowvr, your car is a vr so im pretty sure it will be acrylic. What ive been doing is using eucalyptus oil to soften up the sika, and using a razor blade to CAREFULLY cut it down. When its a very thin layer left, use eucalyptus and either a scraper or a fingernail to get the last of it off
    Slow VR's Avatar
    VR Series II
    Apr 2006
    Cairns, Nth Qld
    Quote Originally Posted by nick88
    Nick
    Wow that looks like u did a good job of that!!!
    Yeah i got plenty of time over this easter break! This Eucalyptus oil mite be something to try!!! I was thinking i could get like dental floss in behind the strip and pull it along to try n slice through it??
    Yeah its stock VR white paint.......
    Holden Captiva (Work Demo)
    Feb 2005
    Quote Originally Posted by semi
    Thats exactly how i get sikaflex off, works a treat, just be slow and steady with the blade and make sure you dont cut the paint.
    Some people say less talk more action, i say more torque less traction.
    VS Commodore
    Jan 2006
    melbourne, victoria
    looks pretty good
    i was going to get the chrome berlina strip to put there but you cant get ahold of the strip without the berlina emblom on it
    -Just Remember White Cars Do It Better-
    VE2 SS Voodoo
    Jul 2005
    i bought a spray can of eucaliptus oil from the supermarket, works good cause ya jsut spray it on and let it soak into the sikaflex, and keep doin that....the more u get off in one go the better......
    if your gunna use a razor blade, be EXTREMLEY careful not to cut into the paint work(or cut yourself too) and go really slow at it and the end result will b similar to mine.....i was gunna stick the red SS mouldings on instead of the stocko black ones, but i thought fark it! went to too much effort to get it looking like it is now to go n cover it up again.
    Nick
    Slow VR's Avatar
    VR Series II
    Apr 2006
    Cairns, Nth Qld
    Nick
    True DAT!!!!!
    Slow VR's Avatar
    VR Series II
    Apr 2006
    Cairns, Nth Qld
    Im over it, got some eucalyptus oil, let it soak in for ages and kept puttin it on, slowly slowy got the thing to budge, kept pouring oil onto it!!! After bout n hour finally got the small strip of the gaurd... Then thought F*ck this, this is to bigger job... So i put the strip back on again.......
    VE2 SS Voodoo
    Jul 2005
    bah, u wimp
    its a bitch to do in all honesty, but the end result is worth it i recon!
    Apr 2006
    oi bro so u reckon eucalyptis oil n a razor blade im gunna do it to my vr looks ###in wicked as
    VE2 SS Voodoo
    Jul 2005
    cause ur car is a VR, and they had acrylic based paint, yes thats about the only way you can do it, unless u are going to get the doors re-sprayed
    so just take it carefull and dont rush is
    Nick
    raZel's Avatar
    raZel is offline The ride for life raZel Executive
    VY II Calais
    Feb 2005
    your all gonna hate me for this, but when my VS was around and i pulled my side strips off, they all came off as clean as anything, not one tiny bit got left on my car... i jst washed the area to remove any shitty dust and stuff like that and i was done, took me all of about 10 minutes to remove and wash the car... TOO EASY.. this may or may not have been the trick but i pulled the strips at a really tight angle... like back towards themselves.. meh i dunno
    raZel
  15. #15
    Slow VR's Avatar
    VR Series II
    Apr 2006
    Cairns, Nth Qld
    Maybe they had been off b4, for a respray?? I reckon the rate that i was going it would have taken me 2 full days to cleanly get both sides off..... F*ck that. I got better shit to do then slave over the car on my days off!
  16. #16
    Feb 2005
    Quote Originally Posted by raZel
    raZel
    It sounds like it wasn't stuck on with sikafex OR its just that... you were lucky.
  17. #17
    10 VE SSV,03 VY Exec, 83 Wb Statesman
    Aug 2005
    i was actually thinking of putting on that strip on my ute to stop bastards from dinging my doors holden want about $175 for the lot!
  18. #18
    VR exec wagon
    Aug 2005
    WA
  19. #19
    Jun 2004
    Slow VR's Avatar
    VR Series II
    Apr 2006
    Cairns, Nth Qld
  21. #21
    VE2 SS Voodoo
    Jul 2005
  22. #22
    vr executive
    Jan 2006
    Kalgoorlie,WA
    "slowvr, your car is a vr so im pretty sure it will be acrylic. What ive been doing is using eucalyptus oil to soften up the sika, and using a razor blade to CAREFULLY cut it down. When its a very thin layer left, use eucalyptus and either a scraper or a fingernail to get the last of it off"
    what he said. except with a cloth and elbow grease to get that last bit off. bugger of a job but itll get there just keep working at it a door at a time
  23. #23
    Nissan Silvia S15
    Jan 2006
    Melb - S/E Subs
    hey guys,
    I tried to do this to my car but it got nasty and i removed some of the paint with it.
    see how it is lighter in the spot where the mould was, if i use the oil will it stop that from happening? i'm not sure if its just the paint has faded or i took off the clear coat or something.
    thats the main reason i didnt remove the rest as i didnt want to have a light line all the way along my doors!
  24. #24
    VR exec wagon
    Aug 2005
    WA
  25. #25
    02QIK is offline 1TUFVS 02QIK Executive
    VS Executive S2
    Mar 2006
    Toowoomba, Queensland
    Im not sure if its the same deal, but when i was debadging my car i used a heat gun, then the sticky stuff left over i just removed with wax and grease remover. Worked a treat, was going to try same process for side strippings.
+ Reply to Thread
  1. Removing side bump strips on VSII????
    By mickoss in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-11-2009, 08:25 PM
  2. Removing Strips off side off car!
    By finnbe in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-08-2007, 10:12 PM
  3. Removing Strips off side off car!
    By finnbe in forum VT - VX - VU - WH - V2
    Last Post: 29-08-2007, 09:37 PM
  4. Removing door side strips
    By karlos_1984 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-03-2007, 10:40 AM
  5. Rubber strips around car
    By Blakie in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-05-2006, 09:51 PM
