Dragz
Hey guys and gals i have a problem with my baby...she runs very good untill this happens....i drive and outa nowhere it goes off...and i was searching threw this thread and found the code checking thread and i did a check and i got thease 2 [ Code 46 - No Refference signal while cranking]- waht it mean please help me and i got this one [ Code 47 - 18x reference signal missing]- and what it mean....im really getting frustrated as i am affraid to drive the damn thing =( oh and i got this of another place so can annyone tell me if it could be this [The problem is corrosion (probably not visible) between the plug and socket connector pins. The plug and socket are held together by a bolt in the middle (~6mm), undo this, pull the two apart and work them in and out a few times, then squirt good quality WD40 etc in before reassembling. This is a much more long-lasting fix. The basic problem is that the pins should be gold plated to prevent corrosion but they aren't to cut 10c off the production price for Holden. The WD makes an oil film to keep oxygen out.]
and the mechanic i took it to said that it could be the sensor...oh when it turns off its takes a litle while b4 it turns on..and no worning b4 it turns off nothing at all just off...
Thanks in Advance
Dragz.:b:
Thanks in Advance
Dragz.:b:
