ey mate, i did this a few months back, bring the interior up lookin good i recon.....i used a VHT Colour Dye from autobarn, wored really well and dont need to prime it
heres how to get the gear surround and area around handbreak(centre console too) off/out:
Pull hand brake lever fully up.
Undo zipper below hand brake lever.
Put gear lever into neutral.
Open ashtray and pull up and remove.
Being very carefull lift the gear lever surround up from the rear, near the hand brake. This may take some force and may require a bit of help by using a small pry bar. Do not over force else it may break.
Once lifted from the rear, pull gear lever surround towards the rear of the vehicle.
Disconnect 1x 1 pin plug from cigarette lighter light. This requires the lifting up of tab.
Disconnect 1x 2 pin plug from cigarette lighter.
Lift surround up and turn 90'.
Lift surround up and tilt over gear lever from rear to front.
Mark gear position indicator plate cover for position in relation to white gear lever surround.
Remove gear position indicator plate cover.
Remove plate cover from above PWR/ECON switch.
Being very carefull lift gear lever sliding trim up slightly, twist the rear section down, push slightly forward and pull towards the drivers side of vehicle. Remove trim. Be very carefull not to snap trim in half at gear lever.
Pry small white trim from the front section of the white gear lever surround and remove.
Remove 4x black screws from the white gear lever surround.
Lift white gear lever surround up slightly and twist gear lever indicator bulb holder and pull away from white gear lever surround.
Disconnect 3 pin plug from the PWR/ECON switch wiring.
Remove white gear lever surround.
Loosen 2x large screws from front of centre console. Do not remove just loosen.
Lift centre console lid up and carpet up in the bottom of the console well.
Remove 2x 10mm nuts from under the carpet in the console well. (may be 2x screws)
Close console lid and place gear lever into first gear position.
Lift the rear of the centre console up about 50mm wilst pulling to the rear about 50mm. Lift the rear of the centre console up and over the gear lever and hand brake lever then slide centre console rearwards. Be carefull of electric window wiring (undo plugs at front of centre console underneith stereo surround) if fitted. Remove centre console.
Doesnt take too long to do, then for the dash surround, unscrew the two screws above the dash, pull the facia lose(held in by clips) un do the connections for all the buttons(A/C Demist and Hazard etc) then the headlight one i think you pull the frontnob bit off, turn the inside clockwise and it comes out(opposite for re-installing)
Its all pretty easy to do:thumbsup:
Nick
