+ Reply to Thread
Results 1 to 6 of 6
Thread: No Parkers, Speed Alert, dash lights or shifter lights.. Help..??
    Grommitt Guest
    Default No Parkers, Speed Alert, dash lights or shifter lights.. ~FIXED~
    No Parkers, speed alert, dash lights, auto selector or Plate Light... hmmm
    ok so last w/e i decided to check my error codes by doing the whole paperclip into the diagnostics plug and waiting for the flashes..
    needless to say i got no flashes only my engine light staying on perminantly so i gave up with it..
    i figured everything was fine until it came to about 8-9pm at night and i was going to go out..
    so i get in the car turn her over and chuck the the headlights on and notice i get no dash light, no gear selector light, my speed alert lights up but no digits showing..
    so i chucked it down to parkers to see if anything happened and i got nothing no parkers.. now i know one of my parkers had blown about a week back so i bought a pair of new globes and chucked them in.
    ive gone through all the fuses i can think of that might affect the parkers and none of them are broken / blown.
    i get full headlights fine so i can still drive at night but not that i can see any of my dash..
    any ideas wire guru's..
    EDIT: i was thinking it could be one of the relays maybe but then thought that wouldnt the headlights run off the same relay ?
    thanks
    James
    VSII Calais supercharged
    Mar 2005
    South Coast, NSW
    Same thing happened to me a last year when I tried to check my error codes. I accidentally touched the wrong hole with the paper clip and sparked. Never thought anything of it until that night I saw no dash lights, transission lights, parkers or tail light. Was as simple as a fuse under the steering column and fixed the lot with one new fuse.
    VZ LS1 Calais
    Dec 2005
    South Brisbane
    it will be a fuse mate....the fact that you said your parkers blew a week ago makes me sure of it.
    its likely some of the wiring or contacts are a little funky for the parker that blew and are causeing the fuse to blow, thus everything else on that fuse doesnt work.
    '00 WH V6
    Dec 2005
    Actually had something similar when i stacked my car.
    When we were checking to see if it was driveable we found the parkers (i think), gear selector, and dash lights were gone, however headlights and accessories were all fine.
    Checked all the fuses and they were fine.. never did find the culprit though. It did take a nasty bump so maybe it sent something loose...
    Driving a CURSED WH V6.
    Grommitt Guest
    Quote Originally Posted by Scooter79
    any memory of which fuse it was by any chance ?
    Grommitt Guest
    All fixed im as happy as a pig in sh*t..
    my mate told me to get a light meter and test the top and bottom of each fuse as not always do the fuses blow straight through or something..
    so i did that and turned out it was the first fuse i checked loll..
    the Trip computer fuse was a dud so replaced that and i have everything back..
+ Reply to Thread
  1. Car lights will turn on parkers but wont show normal driving lights
    By james_vrII in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-02-2010, 07:50 PM
  2. No interior lights, dash lights or elec windows vk
    By ported in forum Electrical Wiring / Questions
    Last Post: 18-09-2006, 04:10 AM
  3. cluster lights and speed alert not working
    By tgolds1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-01-2006, 07:47 PM
  4. Dash Lights & Tail Lights fail
    By robert_buntine in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-08-2005, 04:17 PM
