R
Rusty's VS
Guest
Hi guys,
I have recently been expriencing some problems with my commodores engine management system. The car is a VS SII Manual V6 S pack with 168 000Km on the clock. Mods include sports exhaust, cold air induction, finer filter panel filter, ported airflow meter, and powerchip 98 octane memcal.
My problem started a few weeks ago when the engine would just die for no reason, and wouldn't restart until you turn the ignition off for a second or so. I did the self diagnostic test and came up with code 46 and 49. I then when trough the test in the workshop manual and found the DFI module fualty. All was good, then about a week later it stopped agian. But would restart striaght away without going to ignition off. Check the ECU agian and no fualts were present. Did think much of it until two days ago when I gave it a bootfull and it started to miss really bad. I got home and reved it up under no load and the miss was gone. Checked to computer again and code 49 was listed. I thought mabe the Crank angle sensor was faulty and I have changed that today. Got the car back together and took it for a drive. Still missing badly. Turned around came home and checked the ECU again. Code 47 and 49. So I checked all earthing points and cleaned a tightened them. Also tried to clear the codes but the would not go away. (had the engine fuse out for 5min) I accendently started the engine with the paperclip still in the diagnostic plug. I turned it off and started again and when for a drive. Engine didn't miss at all. Got home again and check ecu an code 47 and 49 remain. What is going on with this thing?? :b: Has anyone got any ideas?? Is the ECU on its way out??
Sorry to go on and on, just thought I should give as much info as possible.
Rusty
Rusty
