M
Murmur77
Guest
I just replaced the accessory belt (running power steering) ... since then when I start my car - (either first thing in the morning or after work) ...it sounds like it just doesn't want to turn over. Once it's started it turns over OK...ie run to the supermarket after work and jump in. Has anyone had a similar problem or should I be really looking at the starter motor etc. I've checked the terminals to the battery etc and all is fine.
Cheers :unsure:
Cheers :unsure:
