C
charged6_vsacclaim
Guest
yesterday coming home from work i noticed the oil light came on but it only came on when i depressed the brake pedal hard then it went. so that night i checked the oil levels and they were fine it was full so i didnt worry about it. then today i started my 95 vs acclaim ready to leave work i noticed the engine light stayed on a bit longer than usual. the car was idling too high at 1500 revs it only sits just above 1000 revs when the car is cold. i had to get home so i drove it anyway i noticed that the gears werent changing correctly like from 1st to 2nd changed at 3000rpm and 2nd to 3rd changed at just over 4000rpm. i couldnt work out wat it was so i decided to see my mechanic mate so when i started the car again it was fine. i have no idea wat the problem is. could it be something to do with the ecu? any help would be greatly appreciated.
