Results 1 to 20 of 20
Thread: Rip off mechanics
    1995 VS Executive
    May 2005
    Default Rip off mechanics
    Hey all,
    I got a massive beef with these mechanics in Canberra, For a start i had a bad oil leek from my rear main seal and i rang around different places here im Canberra, starting with the two Holden dealerships. I was quoted prices well above $1000 and around 2 days to fix which i wasnt real happy with, so i rang round a couple of other places to get an idea on price.
    I rang a place here in Belco right near where i live, and they quoted between $600 and $800 and maxium of 2 days to fix, meening i would have got the car back today. Anyways i took the car in on tuesday morning and the guy told me that the entire kit needed replaceing (Sump gasket, the plate containg the oil seal and the seal it self) Anyways they rang up today with the engine still out of the car and said that my steering rack is stuffed and is leaking fluid, which will need to be replaced, and that all the gaskets will def need to be replaced and it is now going to cost me $1800 and i wont get it back untill Friday arvo.
    What i dont get is how something that was going to cost me a max of $800 has now gone up by $1000 just because the steering rack needs to be replaced which should be a much easier job now that the engine and box arnt in the car, i can understand that the price of the rack would be included in that (at over $400) but that doesnt explain why there in an extra $600 - $700 in labor.
    This guy also says that he thinks the car wont pass roadworthy as it is too low, even though its only been lowered about 2inchs in the front and 1 inch in the rear. As soon as i get the car back it will never go with in 500 meters of this place.
    Lifes different when your sideways...
    Check out my Kustom VS: http://forums.justcommodores.com.au/...ad.php?t=30244
    Pete284 is offline Banned
    Aug 2005
    holy s**t, they're arseh**es. i'd be so pissed if i was you. did you even notice the power steering was leaking in the first place, or is he just trying to get some extra cash out of your pocket?
    TheForgotten's Avatar
    TheForgotten is offline only human......
    VR EXEC
    Dec 2005
    quarantine
    what a jip. RMS costs about $20 from holden, not sure about the plate. Rebuilt PS racks go for about 250 on ebay. shouldn't take one day to do both these, let alone a week, that's bullshyt. he only recommended new gaskets coz he wants your $$$, if you ok'd the work it's on you.
    apparently, the early eco's (VS S1) had problems with the RMS plate, something about the hole being cast wrong, so new plates do diddley. just something to be aware of
    1995 VS Executive
    May 2005
    Quote Originally Posted by Pete284
    I had noticed i little bit of red fluid when i got under it, not really on the ground as i was more conserned with the black sump oil that was there, the steering it self wasnt really heavy or anything, acually it was more lighter then heavyer. There isnt much i can do till i get it back as its in pieces at there work shop. When it comes back, names will be published and all will be enouraged never to go near em!
    1995 VS Executive
    May 2005
    Quote Originally Posted by TheForgotten
    Yeah RMS Does cost $20 as i allready bought that. Entire kit including gaskets is about $120, i think.... It was acully my dad that spoke to em this arvo, so im not entirely sure, but this is what he told me. He is replacing all the rack etc with new stuff, and has allready got it half in, if he was talkin to me i would have told him to shove the rack were the sun dont shine and i would have done it my self.
    VR Caprice
    Dec 2005
    The mechanis should only have done the work you origionally asked him to do. If you didn't request for him to do the Steering he should not have touched it without your prior approval. Tell him to put it back the way it was and as you only requested the Gearbox work that is all you want done for the quoted price, sounds like he under quoted on the gearbox just to get your car in there and then found other stuff it's an old trick but works for them 7 out of 10 times. Also ask for your old parts back you are entitled to them unless they used exchange parts, if they used exchange parts you should see it on your warranties. If he's a member of the MTA ring them with your story and be honest with them.
    Slammed VS Berlina
    Mar 2006
    Thats so fcuked up!! When i had my old VR i got the mechanics In kambah to take my engine and gearbox out, take another engine and gearbox out of a wrecked VR and put them into mine. Only cost $1000 in labour. So it shouldn't cost that much for you! I think i might have to stay away from your side of town.
    :b: Need a Tow? Absolute Towing's the way to GO!
    Check out my ride
    http://forums.justcommodores.com.au/...ad.php?t=30239
    VSII Acclaim Bitsa
    Jun 2004
    Did he call and ask if you wanted this extra work done beforehand? Ie did you have a chance to say no?
    ScottB_33's Avatar
    ScottB_33 is offline Go Hard or Go Home
    VTII Berlina Supercharged
    Oct 2005
    Nowra
    This is a classic case of a mechanic underquoting a job to get the work and then after pulling the vehicle apart rings you up to get extra work from you. Its not only the mechanics fault but also your own as you already got two quotes and they were pretty close to one another you said. So surely if you get another quote and it is much less than the other two, in your brain it must tell you that they have to be short changing you somewhere. Why is it that everyone blames mechanics when really half the problems are actually from the customers themselves not understanding how complex and expensive these modern motor cars are becoming. Its the old saying you only pay for what you get!!! So stop bagging us mechanics and take a long hard look at your own practices!!
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Mechanics are only human like the rest of us. If you want your car worked on by a good one then you must ask around and see what people say otherwise you are taking a chance. I've never been to a mechanic in 45 years of driving but that doesn't mean I have no respect for them. I've seen examples of what Hotrod32 has experienced many times and these cowboys who pull these stunts are not 'mechanics' but just what I'd call 'cardsharps' willing and ready to jump at the opportunity to take advantage of someone who is in a corner. All I can say it to try and make the best of the situation and learn from this experience. Don't carry a grudge 'cause life is too short to be carrying a load on your back.
    94' VR Exec
    Apr 2006
    i had sorta the same issue... put my car in for a service and come back with $1400 to pay.. steering rack was screwed too and gasket covers or something? and water pump... all of which except the steering rack i would have no idea if it needed.. my power steering fluid was leaking badly though. Does feel alot better to drive now though
    Nobody Actually's Avatar
    Nobody Actually is offline luxo barge
    VS s2 Caprice 5l = slow
    Aug 2005
    Queensland
    honestly, **** mechanics, if it is some thing you cannot do yourself (I mean shit, you could have rebuild the whole motor yourself in two days and had some change) then take it to a dealer, atleast then, although it'll probably cost you more there is some one further up the chain to point the finger at and ensure it gets done right the first time.
    And scott, the reason everyone blames mechanics is that we TRUST you with our cars and to do a proper HONEST job. So when this invariably doesn't happen, ofcourse people are going to be pissed
    VZ
    Feb 2006
    SE.MELBOURNE
    haha i took my car in to get Road worthy and i checked the lights blinkers and all b4 going on the road and lol when i got there i left the car there for a day and came back the guy changed all my bolbs and stuff and he charged me about 200$ for it and there was nothing wrong with it...oh and there was some oil leakage and he said he will need to replace that too so i told him dont do it now coz i ddnt have the money the roadworthy cost me $1,000 allready and he was like ull need to fix this its worn out ull need this so i was like fix the shit that needs fixing dont give me this and that..so hes like ye allrite but he pissed me off coz he changed my bolbs...so after a week my oil was still leaking so i checked the oil level and was on one line and then i bought oil and a filter and changed it all and now not one drop of oil not one...it looks like to me that mechanics will find annything to rip some1
    off.
    Oh one question.
    Does the person that u buy the car off has to supply the RWC??...coz the car was registered.
    Dragz.
    Aug 2005
    Queensland
  15. #15
    ScottB_33's Avatar
    Oct 2005
    Nowra
    You must remember also that in NSW you must hold a repairers license and have a tradesmans certificate to be a mechanic. In other states this does not apply. In some states you dont have to be qualified at all and can go and place a sign outside some premises and call yourself a mechanic and carry out work. This I believe is wrong and gives many in the trade like myself unfair coverage when we try and do the right thing by all our customers. If state governments would clamp down on non tradesman then maybe this trade would have a better rap than it does.
  16. #16
    VH SLX V6
    Apr 2006
    some times you quote on something and then when u looking in to it more there is more wrong. eg a VN came in with a stuffed starter motor. the welsh plugs were beond gone.the engine bay was cover in oil.after pulling the motor out the rear mail was stuffed. need new timing cover so badly coroaded.after taking the crank out and looking at the berings they really bad changed them to. then after the motor was back in the kick down cable was broken. this was a nightmare job an i worked on it 4 2 days. in the end i did a lot of other things on the car for a carton of beer wheel berings machiend the discs the list goes on.
  17. #17
    flipsyde Guest
  18. #18
    flipsyde Guest
  19. #19
    VS sedan and a VK DRGWGN
    May 2004
    darwin
    Quote Originally Posted by flipsyde
    torch the workshop
    no, torch your computer. stop digging up old threads.
    ECOTEC KICKED IN yO!!!!!!
  20. #20
    vlv8vic's Avatar
    vlv8vic is offline <---Brad Quaid = internet stalker
    M5
    Mar 2005
    Australia
    nah jokin dont really do it ..
    stop posting rubbish/idiot comments pal or you're outta here.
    think about changing your avatar pic too, now you have drawn attention to yourself i dont find it appropriate.
  1. Another mechanics are F!#*ed thread
    By Cheap6 in forum The Pub
    Last Post: 28-01-2008, 10:51 AM
  2. Is There Any Mechanics on here
    By Phoenix21 in forum General
    Last Post: 14-05-2006, 08:28 PM
  3. Mechanics please....
    By StatOmaN in forum General
    Last Post: 08-11-2005, 12:43 PM
  4. Mechanics
    By rebel in forum General
    Last Post: 22-02-2004, 07:40 PM
