Results 1 to 9 of 9
Thread: Fuel Filter on Vr Ute
    1994 VR Ute
    Aug 2005
    Default Fuel Filter on Vr Ute
    Hi,
    I was wondering if anyone knew where the Fuel Filter is positioned on a VR ute Series 2?
    Cheers Ash
    10 VE SSV,03 VY Exec, 83 Wb Statesman
    Aug 2005
    i would say its just near the drivers side wheel directly under the fuel filler underneath the car thats where myne is mynes a series I vs ute
    Toyota Landcruiser
    Oct 2005
    Central QLD
    If ya can find the tank, and the fuel pipes, good bet your very close.
    Generally should be metal and gold in colour and usually covered in dirt and crap, a quick wash underneath should show it up NP.
    Bring all coalition troops home from Iraq before Christmas, and stop the senseless killing.
    VS sedan and a VK DRGWGN
    May 2004
    darwin
    could it be under that cover at the front of the tray? there is a cover there isnt' there? and the fuel tank is under that? just guessing, but guesses never hurt.
    ECOTEC KICKED IN yO!!!!!!
    VS II S-PAK Manual
    Mar 2006
    cant remember where it is on the ute but the best way to find it is to follow the pipes from the tank and u'll find it.
    A Friend In Need Is A Friend Indeed
    Can I borrow your stock exhaust for EPA?
    Aug 2005
    the fuel tank is under the cover in the tray, but as i said in my earlier post the filter is located underneath the car around the same area and very easy to see and to access compared to the fuel filter in the sedan
    1994 VR Ute
    Aug 2005
    Hey thanks, I will check it out. Do you guys reckon it will make the car go better? Acceleration at the moment, is a bit gutless, could this help that probably?
    Cheers Ash
    Aug 2005
    it depends on how dirty it is i guess ive changed the fuel filters on all my cars on a regular basis the only difference ive had is when i changed the filter on my vn i poured the fuel out and it was all gritty also i had to change the one on the ute because it was leaking, try give your throttle body a cleanout that made a big difference on my vt when it was clogged also make sure your air filter is pretty new if you use the disposable ones
    1994 VR Ute
    Aug 2005
    I cleaned my throttle body about a week ago, along with my air filter. Changing the fuel filter, should make a change, hasn`t been changed since I have owned the car ( 3yrs ).
    cheers Ash
  1. fuel filter
    By R Photon in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-04-2006, 09:10 AM
  2. Vt Fuel Filter
    By cuckoo in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-11-2005, 09:51 PM
  3. Fuel Filter
    By statey27 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-10-2005, 09:06 AM
  4. Vp fuel Filter
    By mc92ma83 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-12-2004, 07:39 PM
  5. Fuel Filter
    By beno in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-02-2004, 08:46 PM
