2 SL/ES said:
Gday mate on my vb commodore 253 I was told 6 to 8 drops per minute.also where does the flashlube conect to the engine on a v6 I dont have upper cyl lube on my vr yet. cheers
The recommended ratio of Flashlube to gas is 1 to 1000
The Flashlube bottle is marked in 50 mls so on my VR I use the volume between two marks every 1000 kms approx.
When I had the conversion done by a garage and the Flashlube kit installed it was done by inserting a tee into the tubing that runs from the inlet casting of the manifold to the fuel [petrol] regulator.
It was done with the tee set up so that any liquid in the Flashlube line would run down into the regulator so I changed it so that the tubing to the inlet casting from the Flashlube runs horizontal and the tee'd tube goes upward to near the bonnet then down to the regulator
I also changed the tubing to oil resistant and made all connections with sealant and clamps as the tubing was the wrong material, fitted poorly was kinked, and some joints were leaking and it dosed only 1ml per 1000 kms.
You can get installation instructions from Flashlube so I reckon it would be best to do it yourself
Regards
