Results 1 to 3 of 3
Thread: HELP oil pressure gauge ?
    Blown VS V6 Wag
    Jun 2005
    East Side Syd
    Question HELP oil pressure gauge ?
    Hey need to get an oil press gauge but dont know what pressure range to get, can any one help what is the oil pressure ment to be for an ecotec v6?
    dont mind what format KPA Bar PSI any will do........
    VS Executive, R31, R33
    Jan 2006
    Default oil pressure
    Mine runs at around 410 Kpa, drops back to 380 on the idle when hot.
    Be very careful when installing a tee to the tapped hole for the oil pressure switch.
    The wall thickness in the aluminium filter adaptor is very thin and will crack if you over-tighten the fitting.
    The replacement filter adaptor from GM has addressed this fault and has a much thicker wall thickness.
    CHANDLC's Avatar
    CHANDLC is offline BushBasher
    1996 V6 VS LEXCEN
    Mar 2006
    TOWNSVILLE
    my runs between 60-70psi
    GO HARD OR GO HOME
    check out my ride
    http://forums.justcommodores.com.au/...ad.php?t=33118
  1. Oil pressure gauge
    By sen8or in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-05-2007, 12:11 PM
  2. Oil Pressure Gauge.
    By ElDubya in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-07-2006, 06:40 PM
  3. oil , air pressure gauge
    By Aryashahin in forum VY Holden Commodore (2002 - 2004)
    Last Post: 13-04-2006, 06:21 PM
  4. oil pressure gauge, oil pressure
    By VN-88 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-10-2005, 09:31 PM
  5. Oil Pressure gauge
    By Joshua in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-05-2005, 08:31 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
