Doors "Creaking"
Spilly
39
VS Acclaim
Do any of you guys know of a special grease I can get for door hinges to eliminate door creaking? i've tried WD40 and the rest of the spray on lubes but no change! i reckon a grease on the hinge itself is in order?
Spilly
kopper69
37
VRII Acclaim
I had the same problem and used wd-40. It didnt get rid of the creaking straight away. Took a few weeks but she has been quite since I did it 3 or 4 years ago. Grease might have the problem of getting into the fine gap. I think you will have your success with a liquid lubricant.
Jamie_87
2003 BA XR6
use lithium grease spray, mine been quiet ever since
Haze
melbourne, victoria
VS Commodore
i used grease of the rod in the middle and no more squeek
DaPlaya
97 VS Series II
petrolium jelly is always good, and maybe try graphite that works well too
drewins
swear word
35
Gawler S.A.
VS Commodore wagon
i just squirted a bit of oil on the hinge. fixed it straight away
Macca177
40
Goldcoast
VS Statesman V8
Next time u at a shell servo, grab a chain lube can(sprays white too) fixed mine up for eva i rekons
ChRiDDa
N/A
VE SS-Z Sportwagon
could also be that your checkstrap is rooted... they are around $50 to replace.. remove the 2x10mm nuts in the door, then remove the pin retaining it to the frame of the vehicle..
make SURE you generously lube up the strap, to prevent it from creaking again
96ss
41
perth
96 vs ss
or even a product most holden parts depts should carry called "gm/holden solidoil" hehehe kinda reminds u of chipfat!!
