Results 1 to 9 of 9
Thread: stroker kits
    VR S
    Apr 2005
    Default stroker kits
    hi guys, just wondering whether anyone has any information about VR/Buick V6 stroker kits.
    VR V6 EXEC
    Apr 2006
    madora bay
    yep sure do !! your up for around $10,000. no one will fit the stroker kit without a full rebuild on an older motor so all up thats what your looking at.... you can check out www.comeracing.com or if your in w.a. try www.kec.com.au & go through the engine list !!
    VR S
    Apr 2005
    wizza Guest
    VR V6 EXEC
    Apr 2006
    madora bay
    i got the motor rebuilt at kostecki engine center here in perth. i went with the vr v6 stroker stage 3 engine !! it now has around 200rwhp or 150rwkw basically the same at the tyres as a stock vr v6 has at the motor...
    VZ LS1 Calais
    Dec 2005
    South Brisbane
    i realise this doesnt quite apply to the particular question, but im currently getting my ecotec stroked with a C.O.M.E racing built stroker short motor and re-using my heads (overhauled).
    all up ill be paying around $7k-$7.5k for everthing...short motor, freight, parts and labour.
    VR S
    Apr 2005
    well i just rebuilt my engine, with ACL race pistons, stage 3 crow cams kit, yella terra roller rockers, injectors, rip shift and planning soon to a minispool diff with 3.9 diff ratio. so planning to get dyno tested soon.
    1995 VS Executive
    May 2005
    Hey Sircrusealot, any idea how many KW that come racing ecotec will make? i want to eventually do something simalar to mine.....one day
    Lifes different when your sideways...
    Check out my Kustom VS: http://forums.justcommodores.com.au/...ad.php?t=30244
    VZ LS1 Calais
    Dec 2005
    South Brisbane
    according to the dyno figures from C.O.M.E, their stroker should make at least 200-220kw (200 being the milder cam option) and 380Nm ...this is with un-ported heads, standard t/b and standard maf.....re-tuning with a gen lll maf and ported throttle body would unleash some nice power though.
    you can also get their forced induction stroker which will easily cope with either super or turbo charging.(costs a fair bit more for this one)
  1. RPM USA stroker kits
    By xcop5l in forum V8 Development and Modification
    Last Post: 06-04-2007, 10:39 AM
  2. VN-VS 4.2 litre Stroker kits
    By klaka in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-11-2006, 03:09 PM
  3. Ecotec 4.2 stroker kits
    By smoken-v8 in forum V6 Development And Modification
    Last Post: 03-01-2006, 09:19 PM
  4. Stroker kits for ECOTEC V6
    By cizocizo in forum V6 Development And Modification
    Last Post: 04-07-2005, 07:10 PM
