Slow VR
Another White Crummodore
- Apr 14, 2006
- 357
- 3
- 0
- Location
- Cairns, Nth Qld
- VR Series II
Ok just another fault that i have with this car. Lately there has been a small puddle of nice green coolant on the ground on the passenger side of the car, sort of under the firewall..... Had the system pressure tested, even with the heater tap open, but all was fine....???? Had lost a little fluid from the over flow tank. The guys at the radiator shop couldnt think of wat it could be..... I just replaced the thermostat, as they noticed was leaking a little around the gasket.
Any 1 else ever seen coolant leaking on the pass side of there car??
I cant spot a leak any where and the pressure test picked nothing up either???:hit:
