J
Joes_meat
Guest
I have a Series II VS V6. I've known for a while that I have a leaky power steering pump.
(I found out when my steering started to judder really badly while turning - filling the resovoir tank back up solved the problem.)
However, the judding has come back. The resovoir is filled to the correct level.
The car judders when turning at low speeds and far from full lock. It's a sort of sporadic problem, sometimes it's fine and sometimes its really bad, I think it's worse when the car is warmer.
Does it sound like a power steering pump problem, or a steering rack problem?
Cheers, Jake.
Cheers, Jake.
