fitzy2005
- Jul 27, 2005
- 1,971
- 12
- 0
- Location
- Wide Bay, Queensland
- VY S2 Berlina
hey peoples, just wondering if you have any suggestions for my v6 vr commy,
the problem is, on average 2 out of 15 starts the car will take a lot longer to crank(5 secs longer).. the other times it starts straight away and is all fine, but when it takes a little longer to start, the car runs rough for a few seconds then if change into a gear the car hesitates and sometimes stalls..
its a 1993 vr exec automatic. ive checked for computer error codes and nothing.. ive serviced car, and ive cleaned throttle body and iac valve etc, have had holden reset base idle etc as well.
fuel pump filter and injectors have been replaced, ive had the fuel pressure regualtor changed about 6mths ago (i dont think its the prob as i can smell fuel in throttle body etc).
any suggestions? my valve stem seals need replacing but i cant see this the cause of problem.. i pick my worked heads and all gaskets etc up in 4wks, but i dont think its got anything to do with that, its prolly something small which is bugging me..
any help will be appreciated..
thanks,, Fitzy
thanks,, Fitzy
