auto windows shutting
theburna
66
Wyee
VR Statesman
I just purchased from Ebay a unit to close my windows when I hit the alarm.
work great and will be getting one for my son on payday.
No effort to install and close the window if it rains.
vracclaim2
VR Acclaim S2
Just buy a switch from dick smith and wire it into the power wire, that way for that one a thousand time that you want your windows down but you car locked with your alarm on, you can just switch it off.
97 SEN
44
VS HSV SENATOR
brentons_house
37
VS Executive
I just bought the auto winder upera form jarcar and I think I'm retarded beause I can't work out how to wire it because it says wire one to the motor and one to the switch where on the switch do I wire it??
also how do I find the the trigger which is going to be locking the car and the ignition key wire?
Snotty
37
the shire!
VR Berlina auto s2
i think i can help
I cut into the wires coming directly out of the switches in the center console, there is a wire that comes out of the switch that goes to the motor (up). Ths saves tracing wires all through the car
As for the triger, i simply got a voltmetre and tested the wires running through the grommet into the drivers door. You will find one that give out a voltage (6v i think, but its not important) when you lock the doors.
If you really get stuck i can try and get some photos when i get home tomorrow.
hope that it helped
Snotty
37
the shire!
VR Berlina auto s2
i find it to be more useful for the other passengers in the car that dont wind up the windows.
Having never had a family car with power windows it was all new to me,
i would recommend the unit, i thing its great.
The one i have you can easly set it to be bypassed if you wanna leave the windows down and still lock the car.
my two cents anyway
brentons_house
37
VS Executive
I'll do some mucking around but pictures would be great thanks.
EGG
41
VH SLE
I bought a jaycars one about a month ago but haven't really had a go at putting it in, I was worried I might have to massacre the wiring running under the centre console. Is it easy to put in without making a dogs breakfast of the wiring?
