Results 1 to 5 of 5
Thread: vs clutch
    greatone is offline vuss
    vy ss
    Jun 2005
    Default vs clutch
    my manual gear changes are abit stiff if my clutch was screwed but doesnt feel like it would it make the gear changes stiff or would it just be the gearbox
    VS II S-PAK Manual
    Mar 2006
    if ur clutch was screwed it would be slipping
    A Friend In Need Is A Friend Indeed
    Can I borrow your stock exhaust for EPA?
    angelo.vs's Avatar
    angelo.vs is offline Autobot
    Honda Accord Euro Luxury
    Oct 2003
    Also if your clutch is on the way out, it would be really heavy and as SaGe said, it would slip. It may not slip all the time but it happens when shifting on higher revs. Best bet is to get it looked at. I also read somewhere to put it in top gear while stationary and release the clutch. If its stuffed it wouldnt stall.
    I recently got my clutch changed (same box as yours). It started slipping really bad the night before to a point where I had to really baby it. Luckily enough I did not get stuck on the road.
    vy ss
    Jun 2005
    maginoodle's Avatar
    maginoodle is offline Donating Member
    vy series2 ss crewman
    Apr 2006
    Quote Originally Posted by greatone
    what do u mean by slipping never happened to me what does it do?
    its like when you rev the car up and hold the clutch halfway out.
    you will know if its slipping.
    is it adjusted properly?also there could be something in between the gearbox and the body makin changes harder at different times. i once had a stick caught and made changing into 2nd and 4th harder
  1. clutch kit
    By adamandtanya in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-11-2007, 08:55 AM
  2. clutch
    By lord_davros in forum VL Holden Commodore (1986 - 1988)
    Last Post: 09-05-2007, 07:36 PM
  3. how much, rpm clutch?
    By jay_hman in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-02-2007, 04:53 PM
  4. clutch
    By MY 5.0L VT in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-01-2007, 06:22 PM
  5. v8 clutch kit
    By griffindore in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-07-2006, 10:40 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
