digisol
- Oct 6, 2005
- 537
- 5
- 0
- Location
- Central QLD
- Toyota Landcruiser
Ok now I'm not slack with maintenance quite the opposite, the VS went OK and answered the throttle when tramped if needed.
So what you say, fair enuf, while changing the leaking rocker cover gaskets I had to remove the throttle cable setup to get access to the rocker cover under it and while there undoing the three 10mm nuts and removing the throttle cable part it seemed seemed a logical move to go further.
Not having done it since buying the thing it seemed it may be just a waste of carb cleaner but to my shock the inside of the body was full of crap and essentially restricting air flow past the butterfly, it had to be.
So after a clean of the 1.5mm of baked on black crud hidden behind the butterfly the thing now literally leaps to life at the slightest throttle and has close on 15 - 20% more off idle power hitting the speed alarm heaps sooner and with less throttle than before.
Why bother telling the converted you ask ? it's a safe bet that many others have not ever bothered to clean the sucker as I had not, because there was no apparent problem with the engine, after all it did work fine, above average.
Besides the added off idle power and much faster throttle response it dropped the idle 150 rpm and also dropped fuel use substantially as much less throttle is needed to get it up to speed.
It's now on my yearly list of things to do, after all the two 13mm nuts is not rocket science, and while at it clean the air flow metering block, a simple job definitely worth doing at regular service intervals.
:driving:
:driving:
